Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Crank Pulley Help Please!
Old Dec 10, 2012 | 09:50 AM
waits6561's Avatar
Question Crank Pulley Help Please!
Hello,
I'm working on a 2003 Lancer OZ. The issue I'm having is some oil coming from the Crank Pulley. As of right now I have replaced the clutch, and all seals on the timing belt cover. After I finished all of that I notice a leak coming from the crank pulley area. I can not figure out why it's leaking. It doesn't seem like there is a bad seal because I don't see one anywhere. Can someone please offer some advice. I have been searching all over the web for some assistance and can't get any kind of an answer.
Any help would be greatly appreciated!
Old Dec 11, 2012 | 08:57 AM
03lances's Avatar
Behind the crank pulley holds one of the biggest oils seals on the car . The front main seal/ crank seal is located behind the pulley and timing gear. That would be your problem.
Old Jan 20, 2013 | 12:22 PM
DrDoc89's Avatar
What oil are you running because synthetic oil molecules are small enough to pass through the crank a little at a time
hockeymanw11
Lancer Engine Tech
Sep 5, 2012 04:38 AM
RyanShanley
Lancer Troubleshooting
Jul 11, 2011 11:53 PM
BLKCarbonEVO
11
Jun 13, 2010 12:29 PM
the_cosworth
Lancer Engine Tech
56
Aug 9, 2007 09:16 PM
_EVOlved_
151
Nov 26, 2006 06:04 PM
