Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Question about L gear in the PRNDL shifter.
Old Feb 26, 2014 | 05:43 PM
GraphiteLancer's Avatar
Is it ok to shift from L to D and vice versa while driving or is it bad for the tranny?
Old Feb 28, 2014 | 11:46 AM
Veronica's Avatar
Depends.
If you are going kinda' slow -no problem. At hwy speeds? It will redline and go to fuel cut off.
It is there for using engine braking when going down a mountain (because if you just used your brakes - they would overheat by the bottom when you needed them most!) or as a last ditch effort to slow the car if the main brakes failed.
Take off from a stop and it should limit you to second (third gear?) and that will will tell you what speed you can safely drop it into. (Or read the manual).
I hope this helped...
Old Mar 1, 2014 | 03:26 PM
Yes it did help, thanks for the info. But once I reach redline in L it's ok for me to shift it into D? I don't have to come to a stop before I put it in D?
Old Mar 2, 2014 | 12:20 PM
Originally Posted by Veronica
Depends.
Old Jun 2, 2014 | 09:09 AM
08LancerGTS_62's Avatar
Question: Why are you even shifting from L to D? L is good if you're in snow or as said going down hill, where you want a low gear, if you are driving on normal streets and just DD the car, stay in D. Car would be quicker in D anyways. If you wanna shift a automatic, just get the paddles.
Aristocrat Dave
EvoX 'For Sale' External Engine / Power
339
Nov 15, 2017 09:14 PM
Aristocrat Dave
281
Nov 15, 2017 09:13 PM
nikush
Nov 14, 2015 08:41 PM
elkazX
For Sale - Wheels / Tires
Aug 13, 2015 04:01 PM
richysevo8
100
Mar 2, 2008 08:19 AM
