Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
'03 OZ Cam Seal
Old Mar 24, 2015 | 10:10 AM
KingTowel's Avatar
'03 OZ Cam Seal
Hey there,
I'm running a 2003 OZ Rally and it has a leaking cam seal.
I was wondering if anyone could point me to the best way to get to it, and replace it. From what I have found I need to go in through the valve cover? I plan on doing the timing belt and any gaskets and seals that are in my way. Anyone have some insight?
Thanks in advance!
Edit:
So I confirmed some things as per the FSM. I'll need to take the timing belt and cam gear off, but do I need to get inside? I.E. through the valve cover?
Old Mar 24, 2015 | 02:05 PM
CrAnSwIcK's Avatar
you need to take the timing belt off, remove the cam gear, and the camshaft if I remember correctly...installing the seal shouldn't require any special tools other than generic seal installation dies...
Old Mar 24, 2015 | 02:08 PM
KingTowel's Avatar
Yeah I figured that much as per the FSM and talking to a dealer. Is it possible to do it without removing the cam shaft? I.E. pulling the seal with some pliers or something?
I'm almost due for a timing belt anyway, but if I can do it without going in through the valve cover I'd be a happy camper. If not, I think I'm going to paint the valve cover anyway.
Old Mar 24, 2015 | 02:46 PM
mcgarvey's Avatar
Just carefully dig it out with a sharp pick and a small screwdriver. Be careful not to scratch the camshaft or the seal bore.
Old Mar 24, 2015 | 03:46 PM
CrAnSwIcK's Avatar
the oil seal surrounds the camshaft, so it's impossible to remove it without at least removing the sprocket...the problem with removing the seal without first removing the camshaft is you risk scoring the shaft...if you score the housing in the head, you can patch it with RTV around the outside of the seal, but you can't patch a rotating assembly...my advice is to do it right...might take more time, but ultimately it could save you a lot of headaches...you guys don't have MIVEC, so the valve train is rather simple...opening the valve cover is easy, your greatest concern should making sure timing is correctly set and tensioned when you put the belt back on...easiest thing to do is take your spark plugs out and hand crank the motor until ALL timing marks are aligned...then remove the belt...
Old Mar 25, 2015 | 06:41 AM
KingTowel's Avatar
Thanks for the advice. After talking to my friend who will be helping me out, he suggested we go "***** deep" as well. Thanks for all the help guys! Glad to know this forum is willing to help out car-noobs!
Old May 4, 2015 | 08:17 AM
KingTowel's Avatar
Update:
Just finished replacing the cam seal. Things went pretty smoothly picking it out without removing the cam shaft, it was a little sketchy but I think it will work out!
Old May 4, 2015 | 09:48 PM
CrAnSwIcK's Avatar
I recently did my rear main seal the same way, picked the old one out without removing anything...no leaks so far
hope she holds oil for you...oil and timing belts don't mix
Old May 5, 2015 | 06:52 AM
KingTowel's Avatar
^ exactly. It seems to be all right after a day, I dunno though something seems a bit off.. It might just be my suspicious nature. There seems to be a little too much clicking when the engine is warm and idling. I think I'll get a buddy to look at it, maybe post a video for you guys.
Old May 6, 2015 | 08:58 PM
CrAnSwIcK's Avatar
re-check timing belt tension, and valve lash...
Old May 7, 2015 | 07:10 AM
KingTowel's Avatar
Well I had a tech at the dealership I work at take a quick look at it. He doesn't think there's anything wrong, but suggests I clean my throttle body to relieve some concerns with erratic idle. So far so good!
EvoIIIAj
Jul 18, 2013 06:42 PM
SwabeLife
Nov 30, 2007 04:18 AM
kf6ytc
Jan 28, 2006 07:30 PM
