Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
key wont turn
Old May 20, 2015 | 03:41 PM
gooov's Avatar
key wont turn
i have a 2002 lancer ES. My key wouldnt turn, so i thought it was the ignition lock cylinder. i replaced that, and the car turned on(turned it on and off 3-4 times). An hour later the key doesnt turn again. Could it be the ignition switch cylinder? or something else. BTW i took out the ignition switch and tried moving the key housing inside and it moved freely with no problem.
Old May 21, 2015 | 05:42 PM
gooov's Avatar
i took out the ignition lock cylinder and examined everything over. On the ignition lock cylinder the thin metal rod(trembler?) has to sit on top of the plastic nub. i dont think i saw threads about replacing the ignition lock cylinder but i can post pictures of the replacement and what i did wrong the first time.
Old May 21, 2015 | 11:38 PM
CrAnSwIcK's Avatar
steering wheel lock?
Old Jun 13, 2015 | 04:04 AM
gooov's Avatar
it was exactly the wheel lock. usually turning the wheel slightly and holding it while having the key turned will unlock it, but i found out that you have to turn the wheel left/right while simultaneously turning the key.
mrbkkt1
17
Mar 11, 2013 04:40 PM
Stock-ish
Feb 9, 2011 07:30 PM
bumblebee04
Mar 11, 2010 08:59 AM
SmokinJoe
Dec 10, 2007 06:41 AM
mrbkkt1
Jun 18, 2007 01:19 PM
