Lancer How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in in the Request sub-forum.
Deyeme sway bar bushings
Old Mar 17, 2005, 06:00 PM
Blacksheepdj's Avatar
Installed everything so far. Front takes a while, but they definitely feel better than the stock bushings. Material seems much stronger. The stock ones were looking pretty ratty, so I'm glad I swapped.
After driving, they do seem to improve handling. The car rides well and feels like it turns easier.
Stock front bushing
Deyeme front bushing (in red)
Blurry picture of stock location (on top of a cross-member, near rear motor mount)
Better picture of stock location (passenger side)
Attached Thumbnails Deyeme sway bar bushings-bushing.jpg   Deyeme sway bar bushings-bushing2.jpg   Deyeme sway bar bushings-stockbush.jpg   Deyeme sway bar bushings-stockbush2.jpg
Blacksheepdj is offline
Old Mar 17, 2005, 06:01 PM
Not many pictures, but here we go.
Remove the bolts and pull off the bracket. Slide out stock bushing and slide in Deyeme bushing.
Replace bracket and replace bolts. Done.
Attached Thumbnails Deyeme sway bar bushings-.jpg   Deyeme sway bar bushings-on2.jpg   Deyeme sway bar bushings-on3.jpg
Old Apr 13, 2005, 09:11 AM
Now for the rear install. Much easier, as the bar can be removed from the car. Here's the "for dummies" version.
So we're starting with the bar inside your house. Remove two nuts on the endlinks, and remove the perches. Pull entire assembly. So you're left with this...
Old Apr 13, 2005, 09:13 AM
Remove the two nuts holding the bracket onto the perch.
Then remove the bracket from the bushing.
Now you're left with just the stock bushing.
Slide on the Deyeme bushing.
Attached Thumbnails Deyeme sway bar bushings-pict0002.jpg   Deyeme sway bar bushings-pict0003.jpg   Deyeme sway bar bushings-pict0004.jpg   Deyeme sway bar bushings-pict0005.jpg
Old Apr 13, 2005, 09:15 AM
Now, simply put the bracket back over the new bushing.
Bolt it to the perch.
Here's the finished product.
Now do the other side. Then reinstall your sway bar. Crack a .
Attached Thumbnails Deyeme sway bar bushings-pict0006.jpg   Deyeme sway bar bushings-pict0007.jpg   Deyeme sway bar bushings-pict0008.jpg
Old Apr 13, 2005, 11:36 AM
LancerEvoMR's Avatar
Discuss thread Here!
LancerEvoMR is offline
ArchieBabes
Feb 4, 2007 06:23 AM
vegasboy301
May 11, 2006 07:38 PM
evo81
Dec 13, 2005 07:37 PM
Titaztik
Jul 19, 2005 09:50 PM
vegasboy301
Dec 23, 2004 03:36 PM
Quick Reply: Deyeme sway bar bushings
