Lancer How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in in the Request sub-forum.
Cedia Headlights
Old Aug 19, 2008 | 12:04 PM
phatmitz's Avatar
Cedia Headlights
Before I got these headlights I checked on this forum to see if anyone had posted pics regarding the install of these lights. There is some text about it but no pics. Well since I got lights in for the wife's car I will try and put up a tutorial on what is needed. I got these lights from ebay and it only took 7 days to get here in Nor-cal from Taiwan. They look even better in person than in the pics. The sellers store is
http://stores.ebay.com/Rapidcustoms-Lighting-and-More
I paid 230 for these ones. I know that this model of lancer is not very popular anymore but I figured I'd post any ways. Here's pics I took this morning.
Last edited by phatmitz; Aug 19, 2008 at 12:07 PM. Reason: put wrong source code in for pics
Old Aug 19, 2008 | 12:14 PM
SlvrOz117's Avatar
do you know how to install them?
do a write up if u can
ill be getting these in a few weeks
nice pickup
Old Aug 19, 2008 | 12:18 PM
bcollinstex's Avatar
Tell whom ever said that to DIAF.
Old Aug 19, 2008 | 12:22 PM
phatmitz's Avatar
Cedia Headlights
Yeah my wife goes to school in SF so I have wait till she comes home this weekend. I will do a write up on how to install these lights, including all the parts needed. Just have to find the sockets for the city lights and for the turn indicator on bottom. I even got new wheels for her car so I'll be putting them on too. Kinda curious to see how these wheels will look since its going on a 03 munich silver es. This will be the 3rd set of wheels going on this car.
Old Aug 19, 2008 | 12:43 PM
phatmitz's Avatar
These are the bulbs that I will be using. H1 for low beams and 9005 for high beams had to get the yellow high beams just like that look
Old Aug 21, 2008 | 10:15 AM
phatmitz's Avatar
Update
I checked the other thread about install the JDM headlights and found out that the headlights that I ordered did not have the adapters needed to hold the H1 bulbs in the socket. I am currently trying to get these parts. I have contacted the manufacturer of these lights but, have received no response yet. Any way I posted some questions in the other thread found here https://www.evolutionm.net/forums/sh...t=67014&page=7
Old Aug 22, 2008 | 08:09 AM
phatmitz's Avatar
Wheels
Well got the wheels on the wifey's car. Rota Torque 16x7 40 offset w/ 205/45/16 Nexxen tires.
Now I have to lower it.
Old Sep 7, 2008 | 02:56 AM
phatmitz's Avatar
Well here we go with the tutorial. Finally got all the parts together. Thanks for all the info OZR lancer and 4no. Couldn't have done it without your help.
before
After removing 3 bolts carefully remove headlight. Disconnecting the headlight, frt blinker, and the connector for the frt marker light. Shown is back of stock headlight
Next you want to make a note of socket cut outs on back of stock headlights
When you compare the stock headlight sockets to the Cedia headlight sockets you can see that cedia headlight are missing an extra cutout for both marker and blinker
My solution is simple but not so elegant. Just cut the socket to fit the bulb holders. I did this using only a box cutter very carefully. I found out that the black plastic on the back of the headlight is very soft, so take care when trimming.
Next I prepared my city light holders. I bought some 194 bulb holders from Autozone for $3.99ea and 194LL bulbs for $3.99 a pr. I modified the bulb holders by removing a little plastic under the lugs of the holders.
I connected the city light holder to the wire for the marker lights. Since its a low wattage application I decided to solder my connection.
First test of marker and city lights
Installing the headlights is pretty straight forward. Just install in reverse order of removal. Just remember to hook up blinker and marker/city light connectors. First test fit of both lamps
Blinker operational test
Since I was using a headlight harness I decided to test to make sure connections correct.
Installed harness and routed wires. Decided on using a common ground for high and low beams. Red wires in frt are the grounds.
Since it was getting dark did a functional test. City/marker lights on
Fogs lights on, those are Hella FF50 lights with Mtec yellow bulbs 2500k
Headlights on low beam, Mtec bulbs 5000k
All lights on, high beam bulbs are Nokya 9005 yellow 2500k. Reason for the color, really foggy in Daly City.
Just low beams only
Tail lights DEPO evo VII replica
If any one has noticed the substantial bumper damage in the pics, that is thanks to all inconsiderate drivers in SF.
Well thats it hope you enjoyed the show!!!
Old Sep 7, 2008 | 02:59 AM
phatmitz's Avatar
For more info like where to get parts and headlights check here
https://www.evolutionm.net/forums/sh...ad.php?t=67014
Old Sep 7, 2008 | 06:28 AM
Jehuty's Avatar
That looks aweseome dude, all this for your g/f's car I can't wait till my g/f gets her accord so I can do the same
Old Sep 7, 2008 | 11:28 AM
phatmitz's Avatar
This is my wife car, dont think I'd spend that much on a GF's car.
Old Sep 7, 2008 | 07:03 PM
OZR_Lancer's Avatar
niiice
Old Sep 9, 2008 | 04:35 AM
phatmitz's Avatar
Thanks for your help OZR. Got a question for you, what type of light pattern does your light put out? On my wifes car the low beam pattern does not seem to be even. Has some hot spots, which kinda bother me. It looks like I have to take the headlights off again, cuz I cant get to the adjusters. Seems like there is too much plastic blocking the adjuster. I will take pics later.
Old Sep 19, 2008 | 07:53 PM
OZR_Lancer's Avatar
my left side seems uneven to the right, but it lights up the road ok.. still the lows arent bright enough
not much of a big deal.. but i prolly need to realight the lights though..
oh and yw phatmitz
Old Sep 28, 2008 | 08:58 PM
schang_18's Avatar
dude, i've got those too, their crappier, but they look nicer than the oem lights
