Lancer How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in in the Request sub-forum.
Low and high beam on at the same time
Old Oct 14, 2008 | 01:44 PM
itscypha's Avatar
lol hell ya i jus did the 8k low/ halogen hi and man im lovin it now when ppl flash at me from bein annoyed i get them even more pissed off! how about that!!want it brighter?!?! cant wait for my cedias so i can do exactly what satownridah/02-es-lancer has. the yellows help alot in rain right?
Old Oct 14, 2008 | 09:08 PM
02-Lancer-Es's Avatar
Not sure , but im switching back to white high beams because it looks nicer on the road , but the 3k do look nicer on the car
Old Oct 14, 2008 | 09:12 PM
Juan Martinez's Avatar
Is there anyway you could draw up a diagram of your wiring for your headlights? I'm still alittle confused.
Old Oct 14, 2008 | 09:29 PM
87 High beam positive ( Spliced)
87a Low beam positive( Cut and connected)
85 High beam positive ( Spliced)
86 negative (Spliced)
30 positive going to the bulb ( Cut and connected)
Well thats all thats needed , once you have the relay in front of you , you know what exactly to do since the relay has all those numbers on it , just connect the wires i said to those numbers and its easy
BTW you need one relay on each side
Old Oct 16, 2008 | 09:54 AM
One last quick question. What do you mean by spliced? I'm not big on technical terms, but does that mean tap into or something. T into?
Old Oct 16, 2008 | 10:54 AM
yea just tap into the wire
Good luck
Let me know how it turns out
Old Oct 16, 2008 | 12:35 PM
Good luck
Will do. Its on my list of getting a job, making money, and then buying lights. It may be awhile.
Old Oct 16, 2008 | 12:55 PM
I dont have a job either .
Dont really need one thou
Because i have my business
Old Oct 27, 2008 | 06:01 PM
Ketchup2me's Avatar
Wouldnt your blue and yellow headlights make green?
Old Nov 6, 2008 | 01:45 PM
phatmitz's Avatar
http://www.danielsternlighting.com/t...ys/relays.html
Old Dec 13, 2008 | 06:25 PM
dancer's Avatar
Hi,
Some high tech headlight conversion chat......but all I want is the correct P/N
for GE Nighthawks for my '04 OZ Lancer. The retailers list high beam (9007)
and low beam (9005) but they won't fit. I have only one double filament bulb
per side ie one bulb is both high and low beam. Does anyone know what is the correct Nighthawk P/N?
Could it be possible that part of the problem is due to the daytime running
feature on my Canadian version of the Lancer?
Thanks,
Carl
Old Dec 13, 2008 | 09:08 PM
The bulb for your car is a 9007 which is used as the low and high beam
keepersway
Nov 30, 2016 08:32 AM
tiesto14
14
May 19, 2016 08:52 PM
CanuckLancer
Outlander Sport
11
Mar 29, 2013 04:29 PM
yitzac1990
28
Feb 21, 2008 10:01 AM
novabluebyyou
16
Jul 25, 2003 04:13 AM
