Lancer How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in in the Request sub-forum.
Building my 2002 Lancer
Old Jan 12, 2014 | 08:17 PM
Thahomeboyb's Avatar
I want something that's fun to drive with good exceleration like my friends 530i. I know that's a lot coming from a lancer but I want something with that umph lol ! and top speed kinda even tho I know they top out at like 110. But I want acceleration over top speed. So I figured I go turbo.
Old Jan 12, 2014 | 08:21 PM
RaCh3T8G's Avatar
Do you plan on building the motor or keeping it stock? Not sure if the evo 8 mani works with the lancer but if it does im sure you can keep the motor stock if your not looking for anything over 300wtq. I know that's the limit for us 64 guys with the stock bottom end.
Old Jan 12, 2014 | 08:26 PM
ambystom01's Avatar
No. The Evo manifold doesn't fit and the stock motor isn't good for 300 wtq. That's more than tripling stock output. If he wants that kind of power, he'll have to replace the rods and pistons.
Old Jan 12, 2014 | 08:39 PM
I looking to keep the motor stock . I wouldn't mid being around 220-300ish area for hp. And dang that sucks . What ECU should I reflash it with . And if I replace the ECU do I have to tune it ?
Old Jan 12, 2014 | 08:43 PM
ambystom01's Avatar
If you install a different ECU, yes you need to tune it.
Old Jan 12, 2014 | 08:47 PM
Do you know a ECU to replace the 02 lancers
Old Jan 12, 2014 | 08:53 PM
ambystom01's Avatar
Why do you want to replace your ECU? A decent standalone ECU costs $1000+ and is unnecessary for your power goals.
Old Jan 12, 2014 | 08:57 PM
Was misunderstood someone told me it would increase a little hp.
Old Jan 12, 2014 | 09:05 PM
My gear shift lights by the the shifter don't light up . What lightbulb do I need to fix it .
Old Jan 12, 2014 | 09:06 PM
ambystom01's Avatar
Tuning does.
ambystom01's Avatar
Read your manual.
Old Jan 12, 2014 | 09:32 PM
My car didn't come with the manual ):
Old Jan 13, 2014 | 05:03 AM
Jeffnalex617's Avatar
Do you need to be turboed to flash an evo rom to the ecu
Old Jan 13, 2014 | 09:09 AM
02modlanceroz's Avatar
No, you don't need to be turboed. but it would be pointless. Your stock ROM is fully capable of being tuned for bolt on applications. Either way, you still won't get much power at all going that route. The main reason to go to an Evo Rom is that it has a lot more potential for tuning a turbo setup. You can get a way better tune through out the curve since it has more fields for load, timing, and fuel maps, and if you want a lot more power and wanna make a switch to E85, it's a good idea. The biggest reason I made the switch to an Evo Rom is that I wanted to go speed density, and the Evo roms have a way better tech support.
Old Jan 13, 2014 | 09:14 AM
Can you link me to the Thread I can't find it .
https://www.evolutionm.net/forums/ec...hramod-v7.html
If you have an automatic, I don't believe you can flash an evo rom on your car, and I don't think you could swap and evo ecu into your car. least the last time I was reading on some of the sites, no one had successfully done it.
Thahomeboyb
Jul 20, 2014 02:43 PM
Thahomeboyb
Lancer Engine Tech
146
Jun 22, 2014 03:26 PM
evolutionaryevo
Evo X Dyno Results
Aug 3, 2013 01:03 AM
dancarroll0283
99
Apr 2, 2009 02:00 PM
ProccoEVO
Southeast Region
Dec 10, 2008 12:01 PM
