Lancer How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in in the Request sub-forum.
RRM Piggy Back ECU install (Auto)
Old Mar 13, 2004 | 10:20 AM
pumpdog720's Avatar
Road///Race
Piggy Back ECU
(U.S. Lancer OZ, ES, LS Automatic Transmission)
Sorry No Pin Diagram
1) Disconnect the battery
2) Access the ECU by lowering the glove box door. The left side tab pulls towards you and then comes into the glove box. After that you just pull the right side inward and the glove box will drop down and can be removed off the hinges.
3) The ECU is located to the left and its wires are covered by a plastic plate underneath where the glove box was.
4) Pull the lower cover plate towards you and it comes off exposing the ECU wires.
5) Pull the connectors out of the ECU by pushing in on the tabs and pulling them out.
6) Using the above diagram connect the wires of the Piggy Back as follows.
7) Connect the Piggy Back’s RED wire to the RED/YELLOW wire on ECU pin 47. (T-into the wire do not sever it)
8) Connect the Piggy Back’s BLACK wire to the BLACK wire on ECU pin 48. (T-into the wire do not sever it)
9) Connect the Piggy Back’s YELLOW/BLACK wire to the GREEN/WHITE wire on ECU pin 43. (T-into the wire do not sever it)
10) Cut the WHITE/RED wire on ECU pin 65. (Leave enough wire on both side so that you can reconnect to both sides)
11) Connect the Piggy Back’s GREEN wire to the side of the cut wire that leads away from the ECU.
12) Connect the Piggy Back’s VIOLET wire to the side of the cut wire that leads to the ECU.
13) Connect the Piggy Back’s vacuum line to the line provided and route it to the intake manifold. Use the Tee provided to connect it to the same line used for the stock fuel regulator then cut off a piece of the supplied line to connect to the manifold where the stock regulator was connected.. There is a rubber grommet sealing a hole just behind the passenger side strut. Remove that to route vacuum line from inside the car to manifold.
14) Now, collect your wires and place the Piggy Back in a safe location away from any danger. (Zip times / Velcro seems to work well)
15) Reconnect the battery
16) Start the car and don’t be alarmed at a high revving situation as the ECU is now in learn mode.
17) Allow the car to idle for 5-10 minutes.
18) After idle period, drive the car for 15-20 minutes very conservatively taking care not to rev the car high or drive hard but keep a constantly changing RPM level. If the car tries to stall at a stop give it gas to keep it running so the learning process continues uninterrupted.
19) After the learning period the car should be fine and you should be able to stop the car and it will return to idle without a problem.
20) Shut the car off.
21) Restart the car insuring a good clean start as it has always before install.
22)If all is well enjoy your new Piggy Back and go have some fun. If there are any problems contact Road///Race Motorsports at (562)906-0080.
!!** Although we do supply quick connectors we highly recommend soldering the connections to insure proper and long lasting functionality **!!** Thanks for your support and be sure to post on Evolutionm.net about your satisfaction with the product ***
Old Mar 13, 2004 | 02:21 PM
LancerEvoMR's Avatar
Discuss thread here!
deeman101
Mar 3, 2021 07:56 AM
tx evo
16
Dec 30, 2010 09:05 AM
DangerousDan
04-06 Lancer Ralliart How To Requests / Questions / Tips
Oct 7, 2010 07:18 PM
EvoCorp
Jun 17, 2005 07:43 PM
vtluu
Oct 24, 2004 07:43 PM
