Lancer How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in in the Request sub-forum.
How-To: Manual Transmission Disassembly/Assembly
Old Mar 22, 2015 | 10:17 AM
CrAnSwIcK's Avatar
Old Mar 22, 2015 | 10:18 AM
CrAnSwIcK's Avatar
Reserved for Assembly
Old Mar 23, 2015 | 03:42 PM
jakermeister's Avatar
I'll have to check this out. I'm just now boosting and I'm sure my clutch will start to go when I get a finer tune.
Old Mar 25, 2015 | 12:42 PM
CrAnSwIcK's Avatar
I will be doing more videos in the future...upcoming is the assembly video, as well I will be doing a how-to on disassembling the shafts to replace gears and synchros...thanks for the subscription
Old Mar 25, 2015 | 09:13 PM
Yeah man. You doing anything with your differential? I was thinking about doing a lsd insert (Phantom grip?). One of the lancer guys did one but hasn't reported on long term use. A regular lsd is out of my price range. the only drawback I see is getting metal shavings, which is probably bad. Lol
Old Mar 25, 2015 | 09:28 PM
CrAnSwIcK's Avatar
I sold my backup "phantom grip" LSD conversion to bakuro...My Quaife LSD has been hopping from transmission to transmission, still holding strong even if the tranny doesn't
If you're looking for a conversion, RTM Racing can make them...they don't list them on their website, but they need only to modify the DSM ones slightly to fit a lancer diff...https://www.rtmracing.com/xcart/prod...d=16815&page=1
Old Mar 25, 2015 | 09:53 PM
Nice!!!! Yeah I might go with a insert. Nice to know there's another source for inserts. I'll look into it a bit more when I need to install my clutch.
Old May 3, 2015 | 01:38 AM
Cranswick,
With a insert or a full lsd do you need to change your fluid more frequently? Or do the fluid changes stay the same? Also what fluid are you running?
Old May 4, 2015 | 09:41 PM
CrAnSwIcK's Avatar
under normal driving conditions, manual transmission fluid should last a long time...now I change fluid more often, because I'm always breaking transmission parts, but I only go with Redline MTL, I've tried all the others, and Redline seems to perform the best...usually every spring I do it, and when it comes out the next year it's pretty clean, unless I had a breakage...
seankhan
49
Nov 26, 2019 01:43 AM
AWDTFTW
Jan 25, 2015 11:51 AM
blk-majik
Aug 7, 2005 02:02 PM
