DVD player problem
Old Apr 17, 2008 | 07:20 PM
ralliartboy9889's Avatar
DVD player problem
ok i just got a savant 7inch touch screen headunit which i really like just for some reason i can get my ipod video or dvd player to work while im driving and i have literally tried everything i can think of ... grounging the wire... toggle switch .... i saw the post lower down but i dont understand anything they are talking about so if someone could please explain a little better thank you
Old Apr 17, 2008 | 11:05 PM
evilevo2003's Avatar
Its Becuz U Need To Have The Parking Break On Did U Install It Ur Self Or Did U Take It Some Where
Old Apr 18, 2008 | 10:32 AM
Jessie55's Avatar
mine works all i did was ground the parking sensor wire...make sure you grounded the wire...the correct wire at that. maybe just take a look through all your wirring to make sure it is all where it is supposed to be
Old Apr 21, 2008 | 01:21 PM
my ebrake wire is a postive its something apparently the thing the new flip outs are doing to prevent people from just grounding it to make it work i alreayd tried grounding it
Old Apr 24, 2008 | 06:53 PM
majestic*'s Avatar
Post a pic of the wiring schematic that came with the unit...
Old May 12, 2008 | 09:41 AM
Jessie55's Avatar
so hook the wire to a positive power source.....accessory wire or cigarette lighter should do the trick
Old May 25, 2008 | 08:44 PM
RalliartJP's Avatar
I had to hook a toggle switch up to something under the shifter where the ebrake is, I believe it was a green wire with just a on/off switch.
Deceit
Oct 2, 2011 03:33 PM
toyotabike
16
Aug 6, 2011 05:43 PM
555R
33
Oct 24, 2007 08:32 PM
Carbonics
Jun 30, 2004 03:10 PM
philberg
May 24, 2004 02:13 PM
