cf headlight housing question
Old Jan 13, 2005 | 06:06 PM
g0damy0uugly's Avatar
hey just curious iono if i put this in the right area but.. i wanted to paint my headlights but.. iw as wondering if it was possible to wrap that piece of metal u paint into carbon fiber... if so what would you have to do...id like to experiment on this or if neone knows POST!
Old Jan 13, 2005 | 06:09 PM
Archangelite's Avatar
well go to www.uscomposites.com and find the CF or kevlar fabric you want. then start your project. it seems like a hard piece to cover, contact sirlancelot, he'll know what to tell ya.
Old Jan 13, 2005 | 06:12 PM
mrbkkt1's Avatar
you would have to make a mold out of the headlight. you could probably adhere carbon fiber directly to your headlight but would be really difficult. i probably would use crea sheet overlays which is kinda like a sticker for this job though.
Old Jan 13, 2005 | 06:19 PM
Dave@Accolade's Avatar
raw twill is a bit hard to manipulate, although you could create the effect by using a CF vinyl which I guess is faux but it would get you the look and easy to cut into shape..
Old Jan 13, 2005 | 06:20 PM
mrbkkt1's Avatar
the only prob w/ vinyl is that he wants to put it in the headlight. the heat will cook the vinyl quick.
Old Jan 13, 2005 | 06:24 PM
hmm.. I suppose your right, but perhaps a lacquer or a temper coat would suffice over the vinyl.
Old Jan 13, 2005 | 06:32 PM
Sir Lancelot's Avatar
I tried to do the cf high heat vinyl on my headlight housings, but the intensity from the headlights began to shrink the material and started to look like crap. I even had a high temp clear coat over it and it wasnt working for me. So I had to go another route and use a composite material that is very pricey and hard to work with. I work with raw cf all the time, and it WILL NOT work inside the headlight. The thickness of the cf and resins will cause the headlight to be distort (?spelling) the way the chrome housing sits in the lens area.
I have cf partial housings on mine, because after I installed my HID's even the composite material couldnt stand the extreme heat.
Old Jan 13, 2005 | 06:33 PM
Dont waste ur time, unless u dont mind going back and redoing the damn lights, trust me! once that vinyl begins to bake in, its harder than a nuns tit, and refuses to come off!
Old Jan 13, 2005 | 08:54 PM
thats quite the expression.
Old Jan 13, 2005 | 10:41 PM
akasirlancerlot's Avatar
cf headlight in my mind is overkill.. when we start to wrap things it just gets poitless.. in that cf is to decrease weight not add pounds.. and its such a fashion statment these days... rofl i have a lot of cf to though.(hood reflectors, and spoiler.)
Old Jan 13, 2005 | 11:50 PM
thanks alot guys... yea i agree about the whole cf thing but....it wuld luk so tite!!!...i guess ill just paint it black
Old Jan 13, 2005 | 11:59 PM
AznFlip's Avatar
^ good idea, or just just buy the JDM Lancer headlights
hotsos
Jan 20, 2010 08:05 AM
iota
Midwest Region
Nov 5, 2008 04:22 PM
ThEHiTMaN
Dec 26, 2004 02:10 PM
SIMSSEGA
Apr 9, 2004 05:26 PM
Kurt
Mid-Atlantic Region
Mar 10, 2004 08:25 AM
