Taking the dash apart
Old Jan 26, 2003 | 04:15 PM
Kralster's Avatar
Question Taking the dash apart
Ok, got a question. I'm wanting to take apart my dash this
summer and do a custom paint job on the dash pieces. I have
located a pair of screws under the a/c and heating gauges. Are
those the screws that I need to take out first, in order to take
out the other pieces of the dash? Also should i have to use a lot
of force to pull out the pieces? Figured I'd ask you guys about
it before I jump in and screw something up. Any suggestions
would be awesome.
___________
With a yellow lancer there's no need to stop at a street light... everyone sees you!
Old Jan 26, 2003 | 04:25 PM
BlackLancer2k2's Avatar
you do need to remove those 2 screws first..above AC controls, and then everything should pop out easy
Old Jan 26, 2003 | 04:57 PM
Rasputin's Avatar
uuuuuuse the seaarrrrrrch....
Old Jan 26, 2003 | 05:00 PM
ZooRacer's Avatar
in the cubbie under da ac controls...dere are 2 screws...den pull of da knobs off...and there are 2 more screws...den jus pull out the cubbie...den take ur hands and go under da ac controls and push out the ac controls and the rest are easy
Old Jan 26, 2003 | 08:35 PM
pearlwhiteoz's Avatar
this is my dash when i took em out...
some bolt under the dash u will need a 10mm socket/wrench and a philips screw driver to take them apart..and that should handle well...some clip might break off..but its no big deal!
Old Mar 25, 2003 | 02:15 PM
fury656's Avatar
Im changing the panel that goes around the ac controls and the radio with the one from the evo, I removed the cubby but how do i go about getting the piece off that i need to change.
Old Dec 6, 2012 | 02:09 PM
JaMRxHanzoxOZ's Avatar
do you know where i can get a how to, to do this? I dont want to forget how to put it all together and have it lay like this forever.
timdog4life
10
Aug 24, 2018 09:47 PM
Rossi_24
May 20, 2016 10:10 AM
dsm_mikey
19
Oct 16, 2009 10:30 AM
rsboy
Apr 5, 2005 09:19 PM
webguy330i
Apr 12, 2004 11:53 PM
