need help with paiting interior!!!
Old Apr 29, 2005 | 07:41 AM
  #46
Kid Lancer 7's Avatar
i already started to... ... excuse the sh!tty mess in the car.. Spring cleaning is about to go down!! lol
Old Apr 29, 2005 | 07:44 AM
  #47
ovenmit331's Avatar
i think i'm painting mine for the opposite reason, so that everything inside is ONE color
Old Apr 29, 2005 | 07:48 AM
  #48
Originally Posted by adotwhite
quik question re: the sanding...i know most of the interior parts are already smooth so i can just paint right over them. is the arrowed portion in this pic the only part i shoud sand? seeing as its a diff. type of surface...
just sand that crap off... get it really good! 200 - 400 grit will do best. dry sand then wet sand the bejezus out of it
the paint i used.
White primer... makes the color POP! (can't u see??)
Krylon Plastic paint. (color of your choice)
Tripple Clear Coat! (1 spray of this stuff ='s 3 sprays of regular clear coat) i sprayed this stuff like 3 times... so i got like 9 coats of clear on lolol looks so bangin though.... get it at walmart! my pieces look like they're dipped in wax... but frikkin dust clings easy to this stuff
Old Apr 29, 2005 | 07:56 AM
  #49
blacklancer03's Avatar
i did my doors.. and they turned out great.
peal the fabric off... sand down the glue stuff on the back and then spray it with krylon. it will give it an awesome fiberglass look. its all good
Old Apr 29, 2005 | 07:57 AM
  #50
if you use krylon. dont sand the woodgrain part. it will look good. just dont put it on to think... sand the other dash parts to get rid of the texture to it.
Old May 2, 2005 | 12:15 PM
  #51
ovenmit331's Avatar
just got done painting my A-pillars this weekend (and front badge too https://www.evolutionm.net/forums/sh...26#post1927726). they're still sitting in my house getting fully "chip resistant" but heres a few pictures. They were taken in a dark garage with a flash, so they make them look SOOOO shiny, but they're not that bad. If they're too shiny after I throw them in the car, I'll go back and throw a coat of flat black on there.
Right before I washed them with Joy soap and rubbed them down with rubbing alcohol
The only non-flash garage door open picture
After 3-4 coats
Where I painted them
what do you guys think? And I'm thinking about doing the b and c pillars as well, but just wanted to do these first to see how they came out.
Old May 2, 2005 | 12:28 PM
  #52
Z_Lancer_Man's Avatar
Looks good! Are you going to change the headliner to black as well? That would look sweet. I knwo a couple of people have used fabric spray paint and some have just glued black fabric over it. Anyway, I say paint your other pillars as well
Old May 2, 2005 | 12:34 PM
  #53
ovenmit331's Avatar
gonna see how these look, then if i do the b and c pillars, i might give the headliner a shot. not sure if i'd wanna paint it, might dust off if touched, or glue something on it (did that in an old car and it started coming down soon after, tx heat is a biznatch)
Old May 2, 2005 | 01:12 PM
  #54
Dreamartist's Avatar
Suade the dash to a color of your choice. A member has done that. It looks beautiful.
Old May 11, 2005 | 09:22 AM
  #55
ovenmit331's Avatar
just finished and installed... heres the pictures of the a-pillars in the car. kinda a crappy day outside so they're not the best pictures.
the pillars came out pretty shiny so i'm thinkin about goin back and re-painting them with flat black. i used krylon fuzion the first time, no sanding, no primer, just really cleaned them well. anyone know if krylon fuzion makes a flat black? I might just go grab any old can of flat and start painting... anyways heres the pics. and click the links to see full sized versions.
http://www.socalevo.net/gallery/albu...illars_002.jpg
http://www.socalevo.net/gallery/albu...illars_003.jpg
http://www.socalevo.net/gallery/albu...illars_004.jpg
http://www.socalevo.net/gallery/albu...illars_005.jpg
http://www.socalevo.net/gallery/albu...illars_006.jpg
http://www.socalevo.net/gallery/albu...illars_007.jpg
http://www.socalevo.net/gallery/albu...illars_008.jpg
http://www.socalevo.net/gallery/albu...illars_009.jpg
http://www.socalevo.net/gallery/albu...illars_011.jpg
http://www.socalevo.net/gallery/albu...illars_012.jpg
Old May 11, 2005 | 09:37 AM
  #56
Looks pretty good ^^
Old May 11, 2005 | 11:39 AM
  #57
looks good mane! semi flat black is the closest to oem. add a mild shot of clear coat to it afterwards. but there is this paint at autozone it comes in a green spray can... it's oem black paint... i used it on my center console and it really does look oem!
Old May 11, 2005 | 11:47 AM
  #58
ovenmit331's Avatar
got a name for the green spray paint can stuff? thanks for your help.
Old May 11, 2005 | 12:45 PM
  #59
nah i really dont remember the name.. but the can is green with a oem black top and it has a pic of a ford explorer on it. next time ur in auto zone check it out
Old May 11, 2005 | 12:47 PM
  #60
if im correct its made by Duplicolor
