Fender rolling...how to?
Old Mar 9, 2003 | 08:53 PM
Smoktout's Avatar
I was just wondering if anyone has rolled their fenders in their OZ yet. im thinkin about doing it, wondering what's involved or how much it cost and if it has any negative side effects. any help is appreciated. thanks.
Old Mar 9, 2003 | 09:00 PM
mark2002lancer's Avatar
never heard of it what it suposed to look like
4Gaijin63's Avatar
what exactly is fender rolling?
Smoktout's Avatar
u can't see it. it's so ur rims dont rub.
Old Mar 9, 2003 | 09:03 PM
4Gaijin63's Avatar
oh fender flaring. never heard it called rolling. i almost did to accomodate bigger tires for my 17s but decided not to. it shouldnt be that hard, just a matter of removing that black plastic stuff...
Old Mar 9, 2003 | 09:04 PM
Smoktout's Avatar
um no, fender flares are a body modification...rolling the fender is something different. u take the inside of the fender (where the tire is rubbing) and roll it away so they dont rub.
Old Mar 9, 2003 | 09:06 PM
evofan@scorp's's Avatar
I've seen it on a civic, but I think you have to cut or loose the inner plastic fender.
Old Mar 9, 2003 | 09:08 PM
4Gaijin63's Avatar
well yes fender flares are modifications, but flaring the fenders simply means making enough room for wheels to fit.
Old Mar 9, 2003 | 09:14 PM
Smoktout's Avatar
ok....so if anyone know's how to roll the fenders...POST IT PLEASE
Old Mar 9, 2003 | 09:15 PM
Body kit .com is comming out with a widebody kit maybe you could just order the fenders
Old Mar 9, 2003 | 09:16 PM
Smoktout's Avatar
omg stop....fender flares are NOT THE SAME AS WHAT IM TALKING ABOUT. please if u dont know what im talkin about...DONT POST!
Old Mar 9, 2003 | 09:23 PM
4Gaijin63's Avatar
lol he has a point tho, with new fenders you would be able to completely remove the plastic crap. but im sure you dont want to buy a kit just for the purpose of fitting bigger wheels.
common sense says that no forseeable negative side effects can com from flaring your fenders as the black plastic crap does not support anything, im sure you could get an estimate from any shop where they have a saw. depending on the tools you have you might be able to do it yourself...
Old Mar 9, 2003 | 09:24 PM
zlancer's Avatar
omg some of you ppl post the stupidest things...any way...
Ben there are a couple of ways you can do it. the best way is to use a torch and actually heat up the inside of the fender. then you can mold it out. but this requires a lot of skill to do right without messin it up. your probably going to have to redo the paint as the extream heat will make it look like ****. another way is to actually cut the inside of the fender and bend it up. i havn't looked at the inside of the lancer's fender so i don't kno if there much to cut, but you again have to be careful because if you leave any sharp edges and your tire hits it it will explode.
or you can have a body shop actually cut out your fender and bend and mold it back together for more clearance. it can get pricey tho.
Smoktout's Avatar
do u think removing the inner fender would cause any problems with water getting into the engine bay or inside the body n cause rust?
Old Mar 9, 2003 | 09:25 PM
I no what your talking about I was just trying to offer you a sulution you want to roll your fenders out so you can put a wider rim on but its not going to look right if you roll them out and dont have any thing to mach
