Air Suspension Installed
Old Mar 23, 2003 | 12:08 AM
zlancer's Avatar
cylindar
Old Mar 24, 2003 | 01:57 PM
Michael's Avatar
Thumbs up nice!!
Old Apr 2, 2003 | 11:08 PM
zlancer's Avatar
look how low it can get now! ....i made brackets and installed them...what a pain in the ***......tomorrow is installation of the front!!! wooooooooooo
Old Apr 2, 2003 | 11:09 PM
zlancer's Avatar
another shot.....pretty ****ty...will get better ones tomorrow
Old Apr 2, 2003 | 11:14 PM
azyan's Avatar
dam Z them air ride is some cool stuff
Old Apr 2, 2003 | 11:15 PM
pearlwhiteoz's Avatar
ha sweet man now u dont need a lift to work on ur car...heh..and u can go offroading w/ it...yeah!!! rock on
Old Apr 2, 2003 | 11:50 PM
2003lancer's Avatar
where did you get your kit? and how long did it take you to install the tank, compresor and valves?
Old Apr 3, 2003 | 06:25 AM
zlancer's Avatar
i pretty much jus pieced the kit together. two placed i got stuff from was www.aimindustries.com and www.truckinsuspension.com the tank valves and compressor took about 6 hours to put in and work right.
Old Apr 3, 2003 | 09:55 AM
SirK's Avatar
dude you have to do a howto for us all
not really up with air suspension, but does that cylinder replace the strut ? or the whole struct/spring etc ?
hows the ride feel ?
Old Apr 3, 2003 | 02:33 PM
zlancer's Avatar
if you can replace stock struts then you can put these things in...there isn't really a how to...same as any suspension setup..its all bolt on.
ride can be adjusted to how i like it....rock hard or very soft...or anywhere in-between...also handles great surprisingly.
Old Apr 3, 2003 | 02:50 PM
crusin_lancer's Avatar
You control the height with a playstation controller? YOu have a pic of that because I have a friend that has air ride and he has pressure gauges and switches in his glove box.... How did you pull that one off?
Old Apr 3, 2003 | 02:56 PM
OZevoVII's Avatar
Lookin good Z! a lot better when you installed the U brackets...lookin forward to seeing the air struts.
Old Apr 3, 2003 | 02:59 PM
gokusupersaiyen's Avatar
so you can adjust how soft or stiff the ride also right?
if you make it stiffer does it affect the height of the car?
Old Apr 3, 2003 | 08:18 PM
?? any answer ??
Old Apr 3, 2003 | 08:41 PM
zlancer's Avatar
every so many psi increase will raise the car...so there are intervals.....you can buy the playstation controller anywhere..jus search for it. air struts are in...jus need to take pics.....i can't wait to surprise people at car shows.
