Headunit problem
Old Mar 9, 2006 | 11:16 AM
TougeOZ_04's Avatar
Headunit problem
did every one have a problem installing there aftermarket head unit?
i talked to a guy who had a problem with it
about it not clicking in
i'm installing that dvd player i posted up
http://www.bestbuy.com/site/olspage....=1108125505761
i was told i would have to glue it in there? does anyone have anyother indeas?
Old Mar 9, 2006 | 12:05 PM
eehjay's Avatar
Dude, I've already told you that once you take out the stock head, there are metal brackets on the side that you have to remove and put on the aftermarket one. I'm not sure if it's different for you, but everyone else on here has done it this way, and it worked for everyone else.
Old Mar 9, 2006 | 12:16 PM
iamdedbob's Avatar
edit: I was wrong, the lancer rocks and the stock metal brackets that screw to the stock headunit can be removed and screwed onto your headunit.
Old Mar 13, 2006 | 11:59 AM
LancerMarita's Avatar
Yes, the stock metal brackets, that are screwed into the stock headunit, work fine without spending extra money for a dash/ installation kit. The only thing you should have to buy is the harness.
Old Mar 13, 2006 | 12:20 PM
sensui's Avatar
This is very easy to install, just take their advice the stock bracket are so easy to remove. Its only 3 screws on each side. And most aftermarket units has multiple holes on the sides for you to put brackets.
Old Mar 13, 2006 | 01:02 PM
eehjay's Avatar
^^ Haha mine only had 2 screws in it to start with and then I stripped 2, so there is only 1 screw on each side holding my deck in right. Surprisingly it hasn't shifted or anything at all.
Old Mar 13, 2006 | 01:36 PM
ThunderOZ's Avatar
yea my screws from the factory HU worked jst fine
Old Mar 13, 2006 | 02:09 PM
Viciouz's Avatar
yah, installed it no problems when i put in my new head unit. If you can't do it yourself go take it to a audio shop and get it installed before you mess up your wirings or do something bad to your car.
Old Mar 13, 2006 | 07:26 PM
mrtrunks's Avatar
aftermarket head unit- $600 from best buy
wire harness - $20 from best buy
no need for a dash kit cause the Lancer Kicks @55 - Priceless
Old Mar 13, 2006 | 08:23 PM
Walkingchaos's Avatar
Aftermarket harness, 18$. Bout maybe 30-45 min with a crimper and some wire splices and pieces of heat shrink. MAYBE 10-15 min with a screw driver in the car and the new head unit was in. Ive NEVER seen a simpler audio install on any car me or my family/friends has owned. If something isnt working youre doing something wrong or youre not working on a Lancer
Old Mar 14, 2006 | 06:16 AM
TougeOZ_04's Avatar
i got it installed and look good i wil post pic
the only thing is that the black outside to it doens't attach to tight of a fit but looks good
Old Mar 14, 2006 | 01:36 PM
Are you talking about the trim ring of the deck?
Old Mar 18, 2006 | 11:39 AM
lancersibling's Avatar
the HU trim ring just needes to be worked a little bit. I put an alpine in my evo this weekend and i had to mount the ring after i mounted the console piece. looks good!
