Help..Patch hole in trunk
Old Apr 4, 2003 | 05:08 PM
nastea's Avatar
WHat can i use to fill the hole from the Stock Spoiler, now that i have a CF evo vii spoiler, i have a whole where that post use to be. anyone have any suggestions?
Old Apr 4, 2003 | 05:11 PM
DaTenshi's Avatar
Sand your trunk Bondo that hole and re paint
Old Apr 4, 2003 | 06:51 PM
Rallywiz03's Avatar
you can probably go to a hardware store and find a rubber or plastic plug for the mean time until you can get it fixed the right way
Old Apr 4, 2003 | 07:33 PM
NeX's Avatar
NeX
Re: Help..Patch hole in trunk
Apursell,
Go to a rust proofing shop like "ziebart" and see if they'll give ya some rubber plugs. The guy i talked to gave me like 30 3/4inch plugs for free and i only needed 7. Drill out the hole to fit the rubber plug (the factory holes are oblong and very difficult to fit). Drill, put a lil touch up paint err someting arround the metal on the whole so it don't rust, then squeeze the plug in there, you might have to tap it in a bit with a rubber hammer but that should do the trick.
Old Apr 4, 2003 | 09:12 PM
nastea's Avatar
thanks guys
Old Apr 4, 2003 | 09:30 PM
OZBOTS's Avatar
I went to a hardware store also and got some plastic plugs and put some window weld around the bottom so it would'nt leak.Looks great
lancerlover07
04-06 Lancer Ralliart How To Requests / Questions / Tips
Aug 14, 2016 11:56 PM
pstl_pete
Evo X How Tos / Installations
Jan 21, 2010 09:21 PM
lancerlover07
Sep 19, 2007 08:07 PM
ersuley
Feb 20, 2006 02:34 PM
EvAsian
Nov 7, 2004 02:24 PM
