New project installed
Old Jun 7, 2006 | 07:40 PM
Jokiesmurf's Avatar
Brembo Rotors by the looks I think it fits both bolt pattern.
Install with Axxis Ultimate brake pads.
Old Jun 7, 2006 | 08:04 PM
ambystom01's Avatar
What car are they for?
Old Jun 7, 2006 | 08:33 PM
Jokiesmurf's Avatar
My lancer.
Old Jun 8, 2006 | 01:56 AM
gregivq's Avatar
Is this really a good idea to combine Axis brake pads with drilled and slotted rotors?
Old Jun 8, 2006 | 07:01 AM
ambystom01's Avatar
I didn't think brembo made rotors for the ES, did you order ones for the OZ and just find they are both bolt patterns?
Old Jun 8, 2006 | 01:42 PM
Wallesasuaz's Avatar
yea, i thought brembos only came in that goldish bronze color well atleast all the sporty ones with holes and stuff
Old Jun 8, 2006 | 01:48 PM
Handmemyarms's Avatar
sorry to chime in here like an ***, but your "project" sucks, dont call it a project, call it "replaced rotors" or "installed brembo rotors (pics)"
i dont take a dump and call it "project weight reduction"
Old Jun 8, 2006 | 04:07 PM
civilrage's Avatar
I... I love you.
lmfao. true its not to much of a project.. are these the r1 rotors? link plz.
Old Jun 8, 2006 | 04:57 PM
mitsuozboi's Avatar
I kinda read somewhere that on our car, drilled and slotted rotors were bad because they did not allow the brakes to build up enouph heat. Slotted were better but drilled/slotted was overkill. I dont quite remember where I read it but That comes to mind. any ideas on that?
They look good.
Old Jun 8, 2006 | 05:54 PM
Jokiesmurf's Avatar
It a project for me due to me not knowing how to change brake & rotors. Did a good job. only have problems with the clips that hold the brake pad lose 1 had to buy new ones. I thank the How To Install guys for puting up threads that help. One problem One of my lug nut didn't what to come out & it broke, so soon I will put in new stub & tuner lugs.
Old Jun 8, 2006 | 05:56 PM
Jokiesmurf's Avatar
Yes there R1. you will have to call to place an order.
Old Jun 9, 2006 | 07:19 AM
SLVROZ_03's Avatar
Don't you worry about your setup, that's exactly what I have had for the pass 30k+ miles and it's perfect. Mine are Brembo slotted,vented, cross-drilled with Axxis/ PBR Ultimates. Not even a hint of brake fade, or cracking due to it be cross-drilled. Only thing is...right after you wash your car, make sure the ceramic brakes are dry. Do a couple of good stop and go's, before hitting the roads...
Old Jun 9, 2006 | 08:05 AM
Those Axxis are Semi Metallic/Ceramic or Plain Ceramic?
Old Jun 9, 2006 | 09:12 AM
SLVROZ_03's Avatar
Believe they're full ceramic...
Old Jun 14, 2006 | 07:14 AM
olo's Avatar
olo
nice
