Where Did I Go Wrong........
Old Jun 29, 2006 | 10:57 AM
escodotcarter's Avatar
alright well i wanted to switch my turning signal to a constant light and the corner to a turning signal. i read the thread on how to do it. by the way i have and 03 ES. i just flip flopped the wires coming out of both lights and re connected them. so the turning signal is now constant = good. but my corners do no blink when i signal and for some reason the clicking noise when you signal has sped up and they blink much faster.
how the heck do i fix this please help thanks
Old Jun 29, 2006 | 11:03 AM
bump up ....need help
Old Jun 29, 2006 | 11:28 AM
ThunderOZ's Avatar
well about the blinking being faster...i knw if u cut the wires that would happen but i think it always happens when you switch those lights...
Old Jun 29, 2006 | 11:30 AM
ThunderOZ's Avatar
have you checked the bulbs?
Old Jun 29, 2006 | 11:35 AM
yea the bulbs are fine. for anyone else who has done this have u had this problem. or might it be a connection or sumtin.
but if everything was done 100% correctly then they should work right ???????
Old Jun 29, 2006 | 12:35 PM
sykou's Avatar
If i remember correctly isn't the corner marker(the one that lights up stock) connected to another light on your headlight assembly? Might wanna check on that...I can't see any other reason why it would blink faster. When you change blinker bulbs to LEDs i know it causes them to blink faster because of the lower resistance the LEDs have. The power travels thru at a higher rate and the relay sees this and adjusts accordingly... But since you just flipped the wires it shouldn't have any problem. Well check the thing i mentioned above and let us know whats up.
Old Jun 29, 2006 | 12:38 PM
liquidpolo14's Avatar
not 100% sure but i think when the lights start blinking faster it means they are going to burn out...
Old Jun 29, 2006 | 01:32 PM
ILovE WHEELS's Avatar
when u swicth the 2 they will blink faster, mine did, and its ok
Old Jun 29, 2006 | 02:03 PM
05ES's Avatar
a relay would slow down the blinking....so would a resistor
Old Jun 29, 2006 | 02:49 PM
for the people that did this did you do it the way i did....? just switch the wires. because mine dont light up when i flip the blinker switch.?
Old Jun 29, 2006 | 02:58 PM
mscc04's Avatar
Mine did that today after I messed with the turn signal. I didn't switch the turn signal and parking light but the problem was the connection between the bulb and socket. After I pushed the bulb down again it worked properly. This is partially due to using 1156 bulbs instead of using 7507 bulbs.
Old Jun 29, 2006 | 04:16 PM
aight i guesss ill mess around with it and see if it works ill let you guy sknow thanks for the help
Old Jul 1, 2006 | 10:50 PM
TougeOZ_04's Avatar
try leds it works for my 04
HondaTuner
Oct 14, 2014 05:06 PM
Alohatrev808
Jul 6, 2014 11:54 PM
flippymcbean
14
Nov 18, 2013 12:02 PM
llno24
10
Sep 14, 2010 10:58 PM
Tweak3D
Lancer Troubleshooting
Nov 29, 2007 11:06 AM
