custom grill
Old Aug 16, 2006 | 01:27 PM
ILovE WHEELS's Avatar
custom grill
here are some pics of a custom grill that im working on
in the pics the grill is only taped on so the actual fit is alot better
the first pic is just the mold without the bondo and some photoshop to het an idea of what i wanted
these 2 are after i got started with some bondo
its kinda like a ralliart grill but the opening is alittle different, ket me know what u think
Old Aug 16, 2006 | 01:33 PM
Lusion's Avatar
Not bad, are you gonna put some mesh there, or leave it without mesh?
Old Aug 16, 2006 | 02:04 PM
ES_02's Avatar
thats nicee.....and cheaper than buying a grill....... u still to work on it a little bit but i think its gonna look good when its finished
Old Aug 16, 2006 | 02:08 PM
sykou's Avatar
might wanna try taping up your bumper while your test fitting it. Looks like you have some scratches already. Did you use fiberglass to make the initial shape for the grill. Might turn out to be a lot lighter if you do.
Oh, and nice job btw nice to see people trying to make there own creations
Old Aug 16, 2006 | 03:31 PM
thanks for all the comments, yea im going to put some mesh in there,as for the bumper being scratched theres tape already on there in that pic, i used clear tape on the hood and bumper. for the intial shape i used foam to shape it the covered the foam w/ bondo.i was thinking of using this grill after i get done to try to make another fiberglass one too
Old Aug 16, 2006 | 03:46 PM
ES_02's Avatar
so you just put foam there and then bondo to smooth it out.... ur not gonna put any fiberglass or anything over the foam??? i thought u use the foam for a mold and then lay fiberglass on it and you get ur grill or something like that.... didnt know foam can be used by it self
Old Aug 16, 2006 | 03:49 PM
foam really cant hold by itself ,i put bondo on the front and back so it seems pretty stong right now. also u cant put fiberglass over foam either cause it kinda melts it, found that out the hard way. ima see what happens with this if its not strong enough when i get done putting bondo on it im going to fiberglass over it to strengthen it
Old Aug 16, 2006 | 05:32 PM
blacklancerr's Avatar
looks like the evo grill......
Old Aug 17, 2006 | 10:18 AM
here are some more progression pics
this 1st pic is me tryin to get the grill to fit almost perfect
almost there
some more flling and sanding and should be done soon
Old Aug 17, 2006 | 10:31 AM
DemisedGabe's Avatar
cool man.
Old Aug 17, 2006 | 01:05 PM
thanks
Old Aug 17, 2006 | 01:39 PM
revolt4revolver's Avatar
good work, man i need to make those kenstyle fog holders.
Old Aug 17, 2006 | 03:16 PM
sykou's Avatar
Wow! The last pic is a HUGE improvement on the older ones. Looking really nice. Cant wait to see it when its all painted
Old Aug 17, 2006 | 08:16 PM
thanks yo
Old Aug 17, 2006 | 10:27 PM
ES_02's Avatar
very nicee.... will look very good when finished..... are you putting mesh after ur done or what........ you should make it so it has that line from the hood it will look better instead of just being flat u know..
