my eyelids need help
If you are worried about the tape falling off, first prep the light by scuffing the top of it where you are going to be placing the tape then use rubbing alcohol to wipe away the loose particles and do the same to the back of the eye lid. next apply with either 3m double sided tape foam or not I tend to use the thin padded tape. Place the tape at the top of the eye brow and it will eliminate the problem with the light. Use some pressure and let them sit for a few minutes before you drive trust me they won't fall off had mine on for 3 years before I changed my head lights.
nope......... I put a strip along the top of the eyelid and then a strip along the front on the front of the headlight (RRM's cf eyelids, 03 lancer) No light shows anywhere and once you push it down and the taoe really takes hold you dont see it one bit.
Back when I first installed them.
pics of them now.. after ive removed them twice....
