my eyelids need help
Old Oct 31, 2006 | 08:54 PM
ohfourLancer's Avatar
well i bought that 2lb strength foam double sided stickies but it seems kinda weak.. i can yank them right off.. is this how it is supose to be or can someone lead me toward a better way to stick the eyelids on my headlights.. and another thing, i was wondering if when on it should block all the light coming from the top, did i place them crooked? or is this how it is going to be.. because there is a slight strip of light sneaking out over the top of the eyelid when looking from above.
Old Oct 31, 2006 | 09:19 PM
help!!
Old Nov 1, 2006 | 04:04 AM
SlvrOz117's Avatar
i used double sided tape
and found out the hard way that glue doesnt really work =/ lol
Old Nov 1, 2006 | 05:52 AM
gregivq's Avatar
Double sided heavy duty tape (over 2 years now )
Old Nov 1, 2006 | 09:37 AM
Silens's Avatar
get the 3M double sided tape not the cheap stuff, have mine on for over 2 years also, dunno what to tell you about the light mine didnt have that problem, maybe stick the tape really close to the top edge so that it covers it??
Old Nov 1, 2006 | 11:06 AM
Enjoi926's Avatar
double sided tape, just apply it the right way, warm up the lights and warm up the eyelids, then stick the tape on, it'll adhere better that way.
Old Nov 1, 2006 | 08:16 PM
oh okay thanks for all of your input
BUT i was wondering if you guys could tell me WHICH double sided tape you guys bought... because i was gona buy the permanate one but it didnt seem too strong.. is this the one that you guys just used? or what brand if any one remembers
it didnt seem strong enough so i bought some foam squares that hold 2lbs but it lets light go out through the top.. that is when looking from above onto the hood/light area.
Old Nov 1, 2006 | 09:44 PM
03LaNcErES's Avatar
i used 3m brand.... isent that everyone one uses... i could give some if u live near me
Old Nov 1, 2006 | 09:45 PM
EVO9MRNJ's Avatar
double sided tape FTW!
Old Nov 1, 2006 | 09:47 PM
03lanceres i live by sandys.. idont supose that im near you am i??
isnt 3M that regular scotch tape brand? ima go longs if so
Old Nov 1, 2006 | 09:54 PM
03LaNcErES's Avatar
yes it is just look for the one that says mounting on it.. and look for the that has the green backing..
Old Nov 1, 2006 | 09:57 PM
03EsLancer where you live?? i never see your car before..
Old Nov 2, 2006 | 01:31 PM
mitsuozboi's Avatar
Yeah. I use 3m double sided FOAM tape.. thicker size. The longer it stays on the harder it is to pull it off. lol.. when I painted my headlights I had to rip the eyelids off and I couldnt even get all the tape off. even with wd40 and a razor blade.
Old Nov 2, 2006 | 03:49 PM
BigP436's Avatar
transtar makes a double sided foam tape that i find works a LOT better then the 3M, and the 3M is overpriced
Old Nov 2, 2006 | 10:45 PM
with the FOAM TAPE doesnt it stick off the light more.. and you can see the foam squares if you look at it from an angle .. and then you can see the light creeping out or will i always see some light comming out
