View Poll Results: Rate this FlipFlop Trunk Modification
Top honors
18
52.94%
Good, but others are better
11
32.35%
Works, but design isn't so hot
5.88%
Stinks. Do not like it with green eggs and ham
8.82%
Voters: 34. You may not vote on this poll
Flip Flop Trunk Modification (new solution)
Old Mar 25, 2007 | 08:57 PM
bsc7080emn's Avatar
Pins ...falling out....
Originally Posted by ThunderOZRacer
ok heres a question...IF those pins (the ones you are supposed to pull out) come out while ur driving for some reason or another will it effect anything?
They won't come out while driving... they have a retaining bead in them, and the hole is sized to fit the pin... so the bead holds them in. Additionally, the natural tension keeps it tight. Good question though.
Old Mar 26, 2007 | 06:51 PM
Rossm's Avatar
I've never been a fan of flip flop trunks but this one looks pretty clean
Old Mar 26, 2007 | 06:56 PM
4wheel_motion's Avatar
+1 for ingenuity
Old Mar 27, 2007 | 01:31 AM
bsc7080emn's Avatar
DIY guide..
Working on a more detailed DIY guide that I can post here as opposed to the link
Old Mar 28, 2007 | 04:21 PM
bsc7080emn's Avatar
DIY Guide for flipflop trunk mod
Flip-flop Trunk Mod
Like the world needs another method on how to mod your trunk to get that flip-flop action, but this one might appeal to those who want to minimize how many cuts and holes they put into their trunk. Also to those who want to easily return the trunk operation back to stock setup.
The approach unusually simple in its approach and requires very few materials, which can all be picked up at your local hardware store for under 25.00 dollars.
Materials are the following :
4 short small flat head machine screws
Note : Pitch thread and diameter should match your
vehicle's OEM trunk lid mount bolts, just substantially
smaller in length.
2 hitch pin clips [secure pivot pins] (3/32” x 1 5/8”)
2 universal clevis pins [used as pivot pins] (¼” x 2”)
2 cotterless hitch pins w/rings [used as locking pins] (¼” x 1 ¼”)
1 inch aluminum square channel tube (4 ft section)
Old Mar 28, 2007 | 04:23 PM
bsc7080emn's Avatar
Equipment needed :
Drill and ¼ inch metal drill bit
Circular saw with metal cutting blade (preferably one that can be used for grinding as well as cutting through the aluminum channel). I recommend using a cut-off blade which works great.
Optional : Someone to help you.
First step will be to cut yourself a piece of the aluminum channel. For my vehicle I cut about 8 inches for each side of the trunk. In the end I only needed roughly 5 inches for each side (you may require more or less), but you will want something to hold onto when you cut your channels. Saves on the doctor bills.
Next, you will need to trim off one side of the channel creating a “C” channel. The easiest way is to trim closely across the length just beyond the length you will be using in the end. Then cut straight across the cut you just made leaving you two pieces. You can discard the thin top piece as you will not need it.
Next you will to trim off the corners slightly, then grind them down so they have nice natural curve to them. Also grind down all the remaining sharp flanges created when you cut the channel. This eliminates any sharp edges and provides for a more professional look.
Old Mar 28, 2007 | 04:25 PM
bsc7080emn's Avatar
Additionally it is recommended that you sand the channel down with some rough sand paper to provide for a brushed metal appearance. It also ensures they are not rough edges that may cut wiring or other items.
Now that you have your pieces cut you will need to determine the placement of the bolt holes by referencing the OEM bolt installs. You will want your holes to be just a little larger than required so that the bolts will seat partly down into the channel. It is important that the bolt heads are not completely flush with the bottom of the channel. You need a little height for the pivot action to work correctly.
Dismount the trunk lid from the support arms. You can now place your newly prepared channels on the arm to verify fitting. Notice here you can easily mark where you need to drill the mount holes on your channel by pushing a pencil through the holes and parking your drill point.
Next you have an option on how you want to approach things. You can either position and mark where you want to drill your pivot holes, then drill the pivot holes using a bench vise OR if you have someone helping you, you can have them hold the trunk lid in place while you drill through the channel and through the support arm. I took the latter approach.
IMPORTANT : You will be drilling the pivot hole in the lower corner of the support arm closest to the trunk lid.
Then drill one more lock position further down the arm. This is the locking pin for
Old Mar 28, 2007 | 04:26 PM
bsc7080emn's Avatar
normal use so that the trunk will close properly when not in display mode. If you haven't yet, mount the channels to the trunk lid using the short flat head machine screws.
After completing the above tasks for both support arms, you can now mount the trunk lid and insert pivot pins. Once pivot pin is inserted, slip on the retaining clips. This will prevent the pivot bolt from coming out.
Then insert the locking pins. At this point, if you had everything lined up correctly, the trunk lid should close and secure properly.
It might be recommended to adjust your latch and trunk lid bumpers so that the trunk is nice and tight for subwoofer activity. We don't want any rattling, though I didn't experience any additional when I did mine.
Now that you know it secures for traveling means, you will want to test out the display mode. Remove the lower locking pin (pull ring). This will allow the trunk lid to pivot.
This is where you will need that friend again. Level out your trunk in display mode so that it is straight and level with your vehicle lines. You will want to drill a third and final hole in the support arm that will hold the trunk lid in this position.
Old Mar 28, 2007 | 04:29 PM
bsc7080emn's Avatar
Once drilled, you simply place your locking pin in this hole to keep it level and clean for display. Abracadabra... No sagging trunk lid.
Depending on your desire, you can paint the assembly. I didn't want the pivot assembly to be the focus, so I painted it black to blend into my black trunk lid. The only chrome metal seen is the locking pin. Other than that, it looks like it was meant to be that way from the start.
Other than that, enjoy your new flip-flop mod. Remember, if you want to go back to stock setup, just remove the channel and reinsert your OEM mount bolts. The only remains of your mods are the 3 sets of holes in each support arm that were used for the pivot and locking pins.
So far I have been very happy with the outcome. Hope it works for you too.
I can be reached at bsc7080@yahoo.com for more questions.
Old Mar 28, 2007 | 04:34 PM
army685's Avatar
good job looks clean well planned out
Old Mar 28, 2007 | 05:10 PM
TougeOZ_04's Avatar
sorry DIY had a easier way to do it
Old Mar 28, 2007 | 05:16 PM
TougeOZ_04's Avatar
http://www.diynetwork.com/diy/ab_aut...529386,00.html
but i love it and i'm going to do it this summer
Old Mar 28, 2007 | 05:26 PM
bsc7080emn's Avatar
Easier to do.... its all in the opinion..
Half a dozen ways to do it... I saw the DIY entry... hated it actually... very crude and unnatural looking, plus did not like the idea of plugging new holes in my trunk lid... again... its a personal choice, so I took some time to think about how I wanted it to look and came up with this idea. Clean, simple, yes some work... but well worth it.
Agreeably, the DIY entry is probably half the cost though. Thanks for the feed back however.
Old May 10, 2007 | 01:18 PM
winter4308's Avatar
Correct me if i am wrong, but i may have misinterpreted what you've said...
There are three holes going into the support arm; 1 is for the pivot point, 2 is for the pin to hold it in place while it is closed. Where is the third hole?
Also, the metal between the trunk and support arm won't raise the sitting position of the trunk when it's closed?
Old May 10, 2007 | 02:07 PM
bsc7080emn's Avatar
3 holes... where and why ?
Though a very basic representation...
*****O* << Pivot Point
*O***** << Display Mode
*****O* << Travel Mode
The pivot point has to be fairly close to the upper right corner in the diagram, while leaving enough room to retain proper strength. The display mode hole is only for display and prevents the setup from sagging, but instead stays level with the lines of the vehicle. The travel mode hole is level with the pivot point and locks the trunk securely for travelling.
As far raising the trunk... the machine screws you use to mount the c-channel to the trunk need to go down fairly flush with the base of the c-channel, but just a tiny bit up from being flush. Reason being, is that that slight raise will assist the pivot action so that the corner of the trunk support (upper right) clears properly without catching on the c-channel. There is a slight raise on my trunk, but I adjusted for it by pushing down the lock mechanism and adjusting the trunk rubber bushings so that they were a bit higher. This made for a very tight setup and also reduced vibrations while putting out some thumping tunes.
I have had no issues with leaks, regardless of carwash or weather.
Here is an image with it closed, and as you can see it is visibly flush to the body.
Also if you look at the DIY guide online here, you can see in some pics, just barely that display mode hole, as it is covered up by the c-channel in some pics.
Hope that helps..
