ES & OZ...different fenders???
I was just wondering what the difference is between the ES & OZ (02-03) front fenders? They are listed separately and the OZ are more expensive but I sure as hell dont see anything?!?
the headlight opening is different so you would have to have evo headlights, which means you would have to use evo front bumper, which means you would have to use evo hood. all of that will fit with pretty much no problems, but its all or nothing.
$40 extra??? where are you getting these and how much are you paying for them??? the place i buy all my oem parts only sells them for like $21 more for both than the es ones. so id assume youre getting raped on the es ones as well. if its more than $200 each, then yes, you are.
Ok...so according to the dealer the OZ fenders has 2 or 3 more holes for clips to accommodate the different ground effects. I will try to stop by the body shop to verify this.
simple fix for that......instead of paying $40 extra for pre drilled holes, just drill the holes yourself. or have the body shop do it. wont affect anything.
