Stock OZ.................LOL
Old Jul 24, 2007 | 11:08 AM
  #31
Brian@RRM's Avatar
btw i dont have a front or rear crash bar, so the air bags wouldnt deploy even if i had the stock wheel.
Old Jul 24, 2007 | 11:09 AM
  #32
ambystom01's Avatar
They should still deploy, front what I can tell the crash bar isn't hooked up to the electrical system thus it's not responsible for the airbag.
Old Jul 24, 2007 | 11:12 AM
  #33
blacklancerr's Avatar
it isn't hooked up to the electrical, but there are sensors inside the support where the crash bar is connected. they would only be triggered with the crash bar in place.
Old Jul 24, 2007 | 11:13 AM
  #34
blaze_125's Avatar
Originally Posted by ek forever guy
Please, explain to me why a 4 point harness is less safe than a 3 point harness.
I looked into racing seats, harness, and roll-cage for a while. I spoke with many people(from cage builders, to driving instructors). In a nutshell, read the following and you'll understand.
The quotes below were taken from 2 different message boards, but the person answering the question stays the same. Emre Kaylap, doctor during the day,driving instructor during weekends.
Originally Posted by JohnathanKong
I just installed racing seats with 4 point seat harnesses, and now people are telling me that it is illegal. Is this true?
Originally Posted by LanEvo
Yes. 4-point harnesses are totally illegal both on the street AND on the track. Nothing less than 5-point is allowed on the track (and only with adequate roll protection and proper mounting).
One of my friends is telling me that I could get pulled over for using a 4 point seat harness. He said it's because cops are only trained to cut people out of 3 points in emergencies.
The reason why they are illegal is because they are deadly. It's that simple.
Without the 5th belt (a.k.a., anti-sub strap) you will submarine under the seat in any sort of high-speed impact. Believe it or not, your stock 3-point belts are designed to protect you from submarining. This is why "tuner belts" are outlawed by the US DOT, the German TUV, Transport Canada, and every race sanctioning body in the world (including the SCCA and ASN/FIA). Schroth did manage to put together a 2" 4-point tuner belt system that got DOT approval. It relies on a break-away strap. Personally, I wouldn't go near it.
Emre
LanEvo and Kayaalp are the same person... but his name changes from board to board.
Originally Posted by Kayaalp
There's more to it than that. Generally speaking, 4-point harnesses can be more dangerous than your stock inertia reel 3-pointer in high-speed frontal impacts as there is no anti-sub strap. We're talking major intra-abdominal blunt trauma (ruptured spleen, liver lacerations, ruptured intraabdominal aorta, etc.) ... this is serious stuff. I'd rather have a bad craniofacial injury than that...you generally don't die from craniofacial injuries. I've spent enough time in trauma centers to stay away from 4-point systems in a road car.
Plus, if you have a harness bar in the car without proper roll protection, you've pretty much signed your own death certificate if you ever actually roll the car. With a stock 3-point belt, you have a chance of surviving: you can get pushed to the midline of the car by the roof as it comes down and be ok. Also, the seatbacks on ALL cars are designed to collapse. If the roof comes down, your seatback can collapse and flatten out. (I know at least 2 people who survived roll-overs this way). This can't happen if there's a steel bar behind you! You'll be broken in half as the roof folds you over it. Not pretty.
Also, if you go backwards into a wall at high speeds the seatback can sometimes collapse...or the seat mounting bolts can snap. This is how the ex-president of the COMSCC died. He spun his Corvette, went backwards into the wall and the mounting bolts on his seat broke. He flew backwards into his harness bar and it broke his neck.
Bottom line: if you are using a stock seat and have no roll protection...use the stock inertia reel belt. If you feel you need more protection, then use a proper 5-point belt with adequate roll protection (4-point bar at minimum). You can use your stock seat if you cut a slot for the anti-sub strap and use a seat-back brace like those sold through i/o motorsport to protect you if the seatback collapses.
Be safe.
Emre
With that being said, hope for the best if you crash
Old Jul 24, 2007 | 11:28 AM
  #35
so one guy says it and it becomes the final say in it??
Old Jul 24, 2007 | 11:30 AM
  #36
yellance's Avatar
yea to bad the law says differently then one guys opnion on the harness huh
Old Jul 24, 2007 | 12:08 PM
  #37
ambystom01's Avatar
If it isn't hooked into the electricals it cannot be the trigger to activate the airbags. Remember the airbags are electrical.
Old Jul 24, 2007 | 12:10 PM
  #38
the sensors located in the front are electrical. the crash bar has 2 beams that go back into the frame of the car. those beams trigger the sensors when pushed back in an accident
Old Jul 24, 2007 | 12:11 PM
  #39
ambystom01's Avatar
It's not one guys opinion, it's supported by facts and basic common sense (ie. physics).
Old Jul 24, 2007 | 12:12 PM
  #40
ambystom01's Avatar
Ah k now it makes sense. I would think that their is also a G-force sensor too, otherwise the airbags would only go off in a front end collision.
Old Jul 24, 2007 | 12:43 PM
  #41
Green_Bandit's Avatar
Yeah...stock huh?
I like it. It's (for lack of better words)...clean.
Is that switch next to the light dimmer in your second to last pic the button for your NOS?
Old Jul 24, 2007 | 12:45 PM
  #42
crypto's Avatar
Former Vendor
so if i get in a front end collission accident without a crash bar the air bags won't deploy???
  #43
ambystom01's Avatar
I would assume it's not nitrous but maybe it's meth injection?
Old Jul 24, 2007 | 12:48 PM
  #44
ambystom01's Avatar
I would think mitsubishi would design the system to have other triggers. Relying on a bar to move seems stupid to me as a lot of factors can affect it (temperature, rust, how lubricated the bar is, etc.).
  #45
crypto's Avatar
Former Vendor
its probably for fog lights or something, it just looks really hardcore
