custom made evo style grille......
Old Mar 30, 2008 | 11:17 PM
  #31
ILovE WHEELS's Avatar
tails look good, i like those wheels too now just a drop would set it off, also that static cling tint is kinda hard to work with. i used a heat gun to help that tint bend around all the curves.
Old Mar 31, 2008 | 12:32 AM
  #32
TheShortBus's Avatar
deff got to give you props on that grille! i work with fiberglass alot with sub boxes and some other stuff on my biddies interior and i wouldnt know where to start with makin that look as good as you did. so props for you.
tints look great i want to do that really bad... damn it i was just at walmart today to...
Old Mar 31, 2008 | 01:19 PM
  #33
billylancer's Avatar
how did you secure the mesh grill
not the frame the grill it self
Old Mar 31, 2008 | 02:24 PM
  #34
ES_02's Avatar
the mesh is sandwiched between the outer part of the plastic.... basically i put the grille down and molded the plastic over it.... so the mesh grille is built into the whole grille... it cant be removed...
Old Mar 31, 2008 | 05:15 PM
  #35
could not be bolted
like OEM one
Old Mar 31, 2008 | 05:19 PM
  #36
ES_02's Avatar
are you talkin about the whole grille..... it still uses the oem holes and screws and clips and everything... the mounting the is the same as stock one since it is the oem one... i just modified the front of it and added more plastic and such.... hah i should sell some of these.... if anyone wants to get rid of their stock one and let me work on it... i have another idea in mind
Old Mar 31, 2008 | 05:20 PM
  #37
did you had to remove the chrome
or just sand it
Old Mar 31, 2008 | 05:26 PM
  #38
ES_02's Avatar
the chrome would have to be removed because the plastic can't fuse with the chrome... i tried sanding the chrome but it was impossible even with 36 grit sand paper... thats where i messed up.. i didnt fully remove the chrome and i might have issues later on....
Old Mar 31, 2008 | 05:28 PM
  #39
do you think that sandblast's to strong
or a metal brush mounted on a drill
Old Mar 31, 2008 | 05:30 PM
  #40
ES_02's Avatar
yeah i wish i could have done one of those you mention man... it dont matter if you get a rough surface since youll be sanding it down many times anyways...
Old Mar 31, 2008 | 05:35 PM
  #41
sound cool to me! one last quest.
what type of primer some for plastic or any one
Old Mar 31, 2008 | 05:38 PM
  #42
ES_02's Avatar
heh i used some anti-rust primer and it came out nice.... you shouldnt worry about that yet.... i think u will end up throwing the grill away dude... lol.. not trying to discourage you or anything... just saying its really hard... pm if you need any help tho..
Old Mar 31, 2008 | 05:46 PM
  #43
like i've sead before mine end up in the trash
TOTALY DESTROID! r.i.p.
so i'm looking for option
Old Mar 31, 2008 | 06:00 PM
  #44
4no's Avatar
4no
the chrome comes off in bleach...scratch it up and put the grill in a tray with some bleach.
Old Apr 1, 2008 | 02:05 PM
  #45
bleach that's it
