GTS HID conversion kit or Evo X headlights
Old May 27, 2008 | 10:21 AM
YeOldeLancer's Avatar
I need to be clarified on this topic. Can regular lancers (DE, ES and GTS) wear Evo X HID headlights? Is getting a HID conversion kit (with bulb, ballast, ect.) producing the same effect? Where can I get evo X headlights?
Thanks!
Old May 27, 2008 | 10:23 AM
stanrc's Avatar
if you buy a HID kit for the lancer you have to worry about the DRL problem, i doubt the evo HIDs plug right in, i'm sure you would need something else. and the only place to get those right now is the dealership for a lot of money.
Old May 27, 2008 | 11:05 AM
ZE Power MX6's Avatar
HID kit won't produce the same effect, you'll need to get EVO X headlight (if they are bolt on) or do a retrofit in your current headlight housing.
Jehuty's Avatar
PMed dude
I don't mind the DRLs. is there another problem associated with them? I would assume the Evo lights are $800+
Old May 27, 2008 | 11:14 AM
Jehuty's Avatar
Alright dude, replied with everything, I had to reply twice, lol
Old May 27, 2008 | 11:18 AM
I just found out what the problem was.
https://www.evolutionm.net/forums/sh...d.php?t=326836
Old May 27, 2008 | 11:50 AM
nunyas's Avatar
try $1500 EACH at the dealership for EvoX projectors....
Galant Forits Projectors are ~$1000 each through Japanparts.com....
Old May 27, 2008 | 11:54 AM
OUCH! I'll pass...
Old May 27, 2008 | 02:48 PM
Jehuty's Avatar
lol lot of money
Old May 27, 2008 | 03:06 PM
nunyas's Avatar
the most ~affordable~ option is to rebuild your stock housings with the projector bits from some scrapped S2000 or RSX projector housings.
Old May 29, 2008 | 03:04 PM
why are the evo x projectors so expensive anyway? I mean, ****, what could be in them to make them so expensive....I don't get it.
Old May 29, 2008 | 04:06 PM
Jehuty's Avatar
They add 100 hp each 0.0
Old May 29, 2008 | 04:19 PM
Nathan0490's Avatar
It's typical dealer rape on part cost for OEM parts. I read on here that someone was quoted $8,000.00 for the RECARO seats from the EVO X...
Old May 30, 2008 | 08:55 PM
WTF? are you serious? How can they even justify that much when you can go anywhere else and get them for 10% of that price! dealerships are lame!
