My 09' Lancer GTS with EVO X Projectors + OEM HID
Old Feb 4, 2009 | 12:38 PM
  #46
Turbotech's Avatar
Originally Posted by zrs
Hey there... nice job and nice writeup too!
Yah, those rumours are bull... my dealer told me it is not possible etc etc but I bought one set from japan and fitted it right on!!!
As I realised for my JDM specced car, the projectors will be plug an play for the following features only:
1) Low Beam HID
2) Bi-xenon High Beam (deflector based)
3) Headlamp levelling (Need to get the OEM switch from parts dealer)
For international version:
Adaptive Lighting System (steering influenced lighting) will not work
For US specced cars:
DRLs will not function, but it is seriously just a matter of pin change, if anyone can get hold of the 09 workshop manual, that cab be accomplished in a flurry.
1 year ago, I bought the oem projectors at about US$2k per set and installed them on my own... US$200 is way too good a deal... Yes, installing them was chicken feat, involve loosening up the front bumpers though, no need complete removal.
Our rides look identical... hehe
Thank you my friend for your info.
So its depends on the wires locations on the harness, well it's a plus that I don't have to mod my projectors or pay someone to turn off the DRL's !!!!!!! I like the look of the projectors without the DRL's.
Old Feb 4, 2009 | 12:39 PM
  #47
Turbotech's Avatar
I think we made a lot of mitsubishi owners happy with this info.
Old Feb 4, 2009 | 01:00 PM
  #48
jRox's Avatar
^Indeed. Especially the 09's. Good job
Old Feb 4, 2009 | 02:45 PM
  #49
eyekyu's Avatar
nice re-writeup! glad to hear that it all plug up. you got lucky and a crazy deal, but buying these projectors for 2grand screw that, ill retro for 900 with better quality
Old Feb 4, 2009 | 04:10 PM
  #50
zrs's Avatar
zrs
Originally Posted by mmartahus
what is this pin change i hear of? what is involved in that. Also all the parts websites have that Leveling switch available , is that plug and play for the US models?
For the 09s, it should be plug and play... for the '08s, maybe not wired up.
The pin change is the deliberate switching of the DRL wires from your ecu to the headlamps. involve some cutting. If anyone can get hold of the 09 manuals, I can do the deciphering for you guys.
Old Feb 4, 2009 | 04:14 PM
  #51
zrs's Avatar
zrs
Yup... now we will have to wait for those wiring information to become available.
For my AFS, I was not able to get it to work simply because the ETACS ecu lacked this functionality. However, the wiring is there, just that it does not work as there is no signal from the command unit, aka, ECU...
You will probably not have problems with the DRLs unless of course you have gotten hold of a JDM specced projector unit, which means that those are AFS lamps instead of DRL. However, if the wreck you salvaged from is local from your dealer, then I don't see any problems...
Cheers, keep in touch.
Old Feb 4, 2009 | 04:32 PM
  #52
Jake26's Avatar
so from what i am understanding that for the 2008 lancer specific the evo x hid's will stay on just like regular headlamps do with the drl's when the switch is to off position and they get brighter when the switch is set to position ON just like regular headlamps?? or do they stay on constantly?? guys with 08 lancer and those headlamps please verify?
Also where do you guys get those evo x headlamps from? and how much?
Old Feb 4, 2009 | 04:41 PM
  #53
eyekyu's Avatar
http://japanparts.com/ 1000 each
or get lucky like dude
Old Feb 4, 2009 | 05:12 PM
  #54
Turbotech's Avatar
Its form a local Evo X US Specs. Thanks again for the additional info!
Old Feb 4, 2009 | 05:23 PM
  #55
Turbotech's Avatar
Mines from a wrecked Evo x.
In the 08 Lancer I don't know if they stays always on. In my case, the projector HID turn on and off with the switch and change between low beam and high beam on the same HID housing (the cirlcle one).
Th other rectancular housing( DRL) are always off, so I can turn on and off the HID while im driving. Remember I have a 09 Lancer with the 2 plug on the harness.
Lancer headlamps: DRL's and low beam are in the same bigger headlamp and high beam is in the small one.
EVO X Projectors: The DRL's are in the square headlamp ( mines is always off) and low and high beams are in the same projector housing( the circle one)
Here is my projector with the DRL off and High beam ON.
Old Feb 4, 2009 | 05:29 PM
  #56
FLOW1's Avatar
Wow, that's pretty sick man! Very nice!
Old Feb 4, 2009 | 05:41 PM
  #57
Turbotech's Avatar
Thanks!! I really want to help others with this info.
Old Feb 4, 2009 | 08:45 PM
  #58
nelsondevicenci's Avatar
ok
in this conversion in my case and i think with turbotech the projector with hid in the 09 can be turn on or off at any time in the o8 you cant do that if you dont leave the lights on all the time when you start the car with the heads switch in off position of course the lights off with out the DRL but if you try turn on the heads they flicker a lot then turn off because the DRL remember you need to change the pins to work GTS 08.
The projector heads are HID from factory so any hid can't be on with dimmer like DRL for that reason on this heads the nesxt beam on the assembly looks like the high beam but is not, is just the DRL 1157 bulb so the projector is a BI-Xenon has a solenoid inside to lower a little pice to see the complete output of light and when in low beam the little part cover the half light output.
In my Knowledge the AFS is a complete different assembly of the heads is a plus to the projector and the autoleveling.
Turbo thech you can take a closer picture for hte two connector to check the color cables?
Thanks
Old Feb 4, 2009 | 09:01 PM
  #59
My next project is install my switch for the autoleveling Mitsubishi part number 8614A038 the dealer say 85 dollars and i said why the mitsubishi dealer in pines told me 55 and the parts guy say wait.....umm ok 55 and i go t the switch the next day.
Old Feb 5, 2009 | 09:17 AM
  #60
Turbotech's Avatar
Thanks
Thanks a lot for that explanation.
I will take some close up pics later.
