Blue guage cluster
Old Dec 13, 2003 | 11:48 AM
twardnw's Avatar
Blue gauge cluster
Changed my gauge cluster over to blue with LED's from http://www.superbrightleds.com/cgi-b...gi?product=CAR . To get the light to spread evenly I glued small pieces of paper onto the ends of the LEDs. Sounds horrible, but works pretty decently. I'll get some pics posted soon.
Old Dec 16, 2003 | 12:43 PM
crnesst's Avatar
Which leds did you buy? I know they are the really small ones but I want to know exactly which ones they are first.
Old Dec 16, 2003 | 06:18 PM
modelchris's Avatar
yo
yeah, what type LED's are they? Did you do the work yourself? How long and difficult was it? And ya gotta get some pics. i wanna have my gauges a diff color. i hate the stock color.
<chris>
Old Dec 18, 2003 | 11:34 PM
twardnw's Avatar
I used the t1.5 LEDs. As for the install, the part that takes the most time is waiting for the glue to dry, if you go that route. If you can come up with a better way to disperse the light, let me know.
If you want actual steps of how to get the gauge cluster out:
1. Remove the two screws holding the black plastic frame aroung the cluster.
2. Remove frame, this takes a little force, or just the right angle. The plastic is fairly flexible though, so don't worry about bending it a little.
3. Remove the two screws holding the cluster in. These are located at the upper right and left edges. To get at the left side a little easier, I pulled out the plastic piece with the mirror control on it.
4. Pull cluster out. Just mess around until you find the right angle to slip it out. Works good fi you rotate the top away from your self. Also, having the mirror control piece popped out helps a lot there too.
5. Dis-connect wiring. This will reset your trip meters, but not the odometer. Press down on the clip and pull out at the same time.
6. Take back cover off of cluster. 4 screws, you'll see them.
7. remove old bulbs, put new in. With the LEDs from suprebrightleds.com they come with a little red sticker on one side. For the backlights of the gauges, put the LEDs in so that this sticker will end up facing the lower side of the cluster, for other LEDs, like the fasten-seatbelt lamp, have the sticker face upwards.
8. Installation - reverse of removal.
If this is a little confusing, let me know and i'll try to set some time aside to take pictures. Also, I'll get the pics of the blue setup, my camera has been acting weird lately, but I'll see if I can get at least one good shot.
Old Dec 18, 2003 | 11:48 PM
Melaz425's Avatar
seems like alot of work for some led's
Old Dec 19, 2003 | 12:07 AM
Sailorgoon's Avatar
Doesn't seem like all that much work...although I really like the red cluster the car comes with, I am certainly interested in detailed instructions and images of the work and finished product.
I look forward to hearing more.
Old Dec 19, 2003 | 01:23 AM
JWERNER24's Avatar
In Timeout
I'd like to see pics.... and also, do these LEDs fit perfectly? like a direct swap? Let us know... and please show pics!!!
Old Dec 19, 2003 | 01:28 AM
Drive02Lancer's Avatar
yeah i wanna do BLUE to cuz blue is the pimp****! or i just cant think of a better color that goes with the ES interior....with a TG exterior
Old Dec 19, 2003 | 01:31 AM
BlackLancer2k2's Avatar
yah..post some pics as soon as possible..i also tried putting led's behind the gauges but they didn't shine thru that well..actually they barely did anything at all
Old Dec 19, 2003 | 11:20 PM
twardnw's Avatar
OK, gonna have a few posts now. Correction to above, there are three screws holding the cluster in. Sorry for the mistake. Here's the first picture, camera still wasn't taking good pics, but you can get the general idea. I'll try using my camcorder to get a good pic when I put it back together tonite.
Old Dec 19, 2003 | 11:21 PM
twardnw's Avatar
OK, now for the steps to get the thing out.
First, remove screws around frame and pull the frame out.
Old Dec 19, 2003 | 11:22 PM
twardnw's Avatar
Now remove the screws holding in the cluster.
Old Dec 19, 2003 | 11:24 PM
twardnw's Avatar
oops, here's the pic for the last post
Old Dec 19, 2003 | 11:28 PM
twardnw's Avatar
Remove the cluster. It helps to pull out the plastice piece holding the mirror controls, and rotate the top of the cluster away from your body. Then wiggle it around till you get the right angle and it slips out.
Old Dec 19, 2003 | 11:30 PM
twardnw's Avatar
Now disconnect the wiring harnesses, two clips, one white, one blue. On the front (when rotated otherwise top, is a detent in the middle of the harness, press in on that and pull out on the harness at the same time to release.
