need info for changeing a gauge cluster
Old Feb 11, 2004 | 12:42 AM
beanutoo's Avatar
i have a 2003 lancer es and i was woundering if it is posable to change the gauge cluster from a es modle to a oz rally? i like the oz rally gauge cluster more then the es . the es is very plane. so if anyoen knows or has done it can you help me out? thanks
Old Feb 11, 2004 | 12:47 AM
DriftRunSir's Avatar
the OZ clusters are interchangeable with ES clusters...just plug and play not definate about the digital mileage though but im sure you wouldn't mind having a low mileage cluster on your car
Old Feb 11, 2004 | 12:49 AM
Sailorgoon's Avatar
This has been covered over and over, try running a search next time, before you make a thread.
But...since we're already here...
You can easily swap the OZ cluster for an ES/LS unit, as they all use the same connections. However, new clusters are VERY expensive and you have the added problem of mileage being stored in the clusters' internal memory.
If you change the cluster, you need to have a government authorized facility record the true mileage on the car before the change. If you have 20,000 miles and swap for a brand new factory cluster, you suddenly have 0 miles.
This is illegal, and is basically identical to old-skool odometer rollback. A few guys have swapped clusters though. After you run a search, you should look them up for more info.
Old Feb 11, 2004 | 01:13 AM
JWERNER24's Avatar
In Timeout
I've done it. I have an ES with an OZ cluster... 5 minute install, and its a mod that adds soooo much to the inside of you car
Old Feb 11, 2004 | 04:20 AM
CulebraLancer's Avatar
I need
I need oz rally guages
Old Feb 11, 2004 | 07:39 AM
keep your eyes open in the Parts/trader section of this forum as well as ebay alot of OZ's being parted recently and some of them were selling their parts for dirt cheap.
Old Feb 11, 2004 | 07:45 AM
Part number.
I wanna start checking in junkyards around my area, does anyone know the exact part number for the 2003 ozrally gauges? If you do please pm it to me or post under here.
Old Feb 11, 2004 | 07:51 AM
Pick_a_Fro's Avatar
say the OZ gauges have 12,000 miles on it. And on the ES it has 11,500. If I drive around my ES another 500 miles, then is it still okay to swap in the OZ gauges w/o going to an gov't authorized facility or wut not?
Old Feb 11, 2004 | 07:56 AM
jtc's Avatar
jtc
Isn't the car's mileage read from the ECU? Confused...
Old Feb 11, 2004 | 08:52 AM
nds34d's Avatar
You would probably be fine just switching the gauges without driving around. As long as the difference isn't too bad, it will never show up as odometer fraud. Odometer fraud would be a very bad thing. If you dont want to do that, switching them when the mileages would definately be ok because no one would ever know the difference.
teammvm
Lancer How Tos / Installations
Oct 5, 2014 05:26 AM
Avirex
16
Aug 9, 2011 06:24 AM
steven121
Apr 5, 2010 12:07 PM
inviziblekid
17
Aug 30, 2008 02:20 AM
sthiewes
Mar 17, 2005 08:07 AM
