HOWTO Req: Taillight replace
Old Feb 11, 2004 | 02:55 PM
blk-majik's Avatar
Question HOWTO Req: Taillight replace
Sorry for the lameness, but I really suck at this stuff and seem to be kinda stuck.
One of my tail lights on my 02 ES has burnt out so I bought a new set of bulbs (12v 7443/BP2's). Anyway, I got the tail light unscrewed (2 screws on the fixture it self), but they are also being held into the trunk. I tried removing some of the plastic push-pin's holding the trunk felt in place and got it off enough to see some rubber-covered push-pins holding the lamp in. I cant get them out! I tried pliers, but no luck.
I also had trouble taking the felt out. I broke 1 of the pins =[ I was using a screwdriver to pry them out. Any recommeneded way to do this better? And what about the lamp itself?
HELP!!
Thanks guys,
J
Old Feb 11, 2004 | 03:12 PM
Guru_Del's Avatar
you take out the two screw in the side like you did then pull the whole thing straight out. the two clips will let go with firm constant pulling.
Old Feb 11, 2004 | 03:13 PM
pgmike's Avatar
i have switched mine a few times. you really dont need those plugs to keep the tails secure, only the two screws are needed. i used pliers to take it off so maybe you just need to put your back into it. when you ge the lamp out there will be 4 bulb sockets. it will be pretty easy to figure out which one it is, just look in the owners manual if you still cant. i actually just had some burn out on me a couple days ago too, bu i still havent replaced it.
Old Feb 11, 2004 | 03:41 PM
blk-majik's Avatar
This thread is like 1 hr old and I fixed it! That was WWWAAAAYYY easier than I was making it. Thats what I get for having my roommate who owns an old rusty dodge help me doing it (grin).
Thanks for the help guys! I hope my lack of knowledge helps someone else who needs to do this!
Old Feb 11, 2004 | 03:43 PM
HobieKopek's Avatar
Gonna put this in show and shine for everyone else.
Old Feb 11, 2004 | 04:26 PM
evomaster's Avatar
try this
llDemonll
Sep 22, 2021 05:43 PM
09GTSLancer
Lancer How Tos / Installations
22
May 24, 2009 11:24 AM
bluewaterDEMON
Sep 19, 2007 07:17 PM
ZapcoLancer
Lancer Troubleshooting
69
Sep 27, 2003 05:10 PM
