How to paint headlight housings (DIY)
black out head lights
I have an 03 lancer oz in yellow. I already have all my windows tinted really dark and a greddy exaust. I want to black out my headlights but im not sure how black would look or maybe yellow does anyone ohave any ideas on what colors i should make it that would be cool. Pics would be appreciated.
Thanks,
Frank Escalle
Thanks,
Frank Escalle
Originally Posted by AznFlip
okay, im busy to read all this pages. But I just tried doing this but I have problem splitting the black plastic and the lense. I did bake it for 5 min. But it's still ******* hard.
ik this is kinda bringing back a dead thread, but i would like to know if you are supposed to paint the inside of the round turn signal part or mask it off or what? cuz wouldnt that kind of hurt the brightness of the turn signal? all the pix i see are ones of the housing inside the headlight, not the housing out side the headlight. so if anyone could help me out, that would be great
My experience
just giving my review on this (I just finished) and what problems i encountered.
1. Dont do it on a cold and rainy day like I did (paint takes forever to dry)
2. be careful when taking the stuff apart. if you get the glue on stuff it is very hard to get off.
3.I did 275 degrees for close to 7 mins. It basically just pulled off once all the black clips were pulled back.
4.Be carefull when you put the housing back into the lense. I broke the "wings" off that screw into the lense. (It got stuck and I pushed to hard). I had to epoxy the "wings" back together.
5.if you want to change bulbs this is a great and easy time to do so.
6. only need one can of primer and paint. I bought two of each. way to much...
7.it looks great. I recomend this mod to anyone that has the patience to do it.
8. I used the directions in the How to section by digdat. they were great.
Those look good, i did the same to my mirage headlights a long time ago, the process does work if done correctly... so far, by the pics that have been posted, the HL's look badass!!! i might try the same.
