How to Install JDM Headlights
Old Dec 9, 2008 | 10:06 PM
  #136
OZR_Lancer's Avatar
lol i can assure you that at night time it shines through the lamps blacked out housings just fine ... those ones night evolution sells are real cedias.. and the turn signal light is hella nice through the clear lense
the "other" lamp with amber turn signal lense is from the cedia wagon...
there is one on ebat atm thats a "fake" cedia for the 02-03.. some reason it doesnt look right
Old Dec 9, 2008 | 10:25 PM
  #137
02-Lancer-Es's Avatar
Originally Posted by shutout809
has anyone opened em up?
I opened mine once because i got water in them but closed them back up after i dried them
and i dont think any of them on ebay are real unless they have the Stanley logo on them , because i know mine are fake
Old Dec 10, 2008 | 10:19 AM
  #138
shutout809's Avatar
thanks for all your imput guys i appreciate it
Old Jun 24, 2011 | 09:13 AM
  #139
LancerBri1120's Avatar
I know this is forever after but I got my highs and lows running, the problem i have is getting the blinkers to run because I feel like I've tried every combo of wire tying lol. Please someone get back to me asap.
Old Jun 24, 2011 | 02:09 PM
  #140
OZR_Lancer's Avatar
ok so you properly ran the hi/lo hot wires to the proper areas along with spliting the ground too right? so the lows come on the outer part of the housing and hi comes on the inner housing part right ?
the blinkers are a seperate wire altogether, it should plug right in to the cedia housing. if thy have trble going in, i had to use a exacto to trim some of the plastic off to make it go in, pretty simple to do...
if possible can u post a picture?
Old Jun 25, 2011 | 04:29 PM
  #141
Yes. those wires are done, the only problem with that is what does the bulb for that sit in? I'll take a picture of the problem I have & with the blinkers I'll take a picture as well.
Old Jun 25, 2011 | 10:11 PM
  #142
OZR_Lancer's Avatar
look at post #109 https://www.evolutionm.net/forums/la...dlights-8.html it has all info u need
4n0 discovered this in thread above... 2005 Mitsubishi Outlanders share the SAME H1 socket adapters as cedia headlights
tht thread post shd explain everything..
Old Jun 25, 2011 | 10:12 PM
  #143
OZR_Lancer's Avatar
ok post it when u can
Old Jun 26, 2011 | 06:16 AM
  #144
This is what it looks like right now.
Old Jun 26, 2011 | 02:09 PM
  #145
OZR_Lancer's Avatar
wheres the h1 socket adapter that the h4 pligs into lol and whats going on with that turn signal wire???
i hope u dont have any wires crossed
if u look at prev post he has a pic posted of tht the harness looks/should look like when finished
why does it look like u have the turn signal wire cross/split
Old Jun 26, 2011 | 04:28 PM
  #146
I bought this whole setup from pgd_Lancer. I'll pay someone to help me out with this cuz I'm stranded with no car until I have the headlights wired correctly. I knew I was missing parts to this.
Old Jun 26, 2011 | 08:26 PM
  #147
OZR_Lancer's Avatar
their shd be only 3 set's of wire runs per side..
... one for headlights hi/low [ the 9007 that you have to split properly),
...2nd is the city light/amber side marker and
....3rd is the turn signal wire
ill take a pic of mine for you to compare and ill post it up
Old Jun 26, 2011 | 08:31 PM
  #148
Alright Thanks OZR
I'm headin down to my boys house tomorrow cuz he has all the tools to fix this problem. I just need to know all the parts I need to finish the install.
Old Jun 27, 2011 | 12:51 AM
  #149
OZR_Lancer's Avatar
1] is 9005 hi beams
2] is h1 low beams
3] is amber side marker
4] is amber turn signal marker
now the 5th hole u see is the optional city light marker tht u prolly have to splice it into the amber side marker signal is the image [3]
#3 comes off the main harness on both sides theirs really no need to splice into any of them unless u want the city light
this next image is the harness i made.
this way its easier to plug it into the oem harness and it splits the hi and low beams and its neater
Old Jun 27, 2011 | 07:35 AM
  #150
1] is 9005 hi beams
2] is h1 low beams
4] is amber turn sifnal marker
Where did you end up putting the ballust boxes on both sides.?
