Console Lights All-In-One How-To
Old Mar 5, 2004 | 04:36 PM
jtc's Avatar
jtc
Thumbs up Console Lights All-In-One How-To
Okay boys (and girls) here we go. Everything you ever wanted to know about changing light bulbs, clock colour, dismantling your center console in one handy dandy thread.
Tools needed: nothing but a phillips (otherwise known as cross) screwdriver. Really. It's not as hard as you thought it was.
UPDATE:
I now have both BLUE and RED filter gel in stock. Also, I can get my hands on GREEN and YELLOW if there is interest.
Cheers!
EDIT:
I carry the gels to do this mod. I currently stock red and blue, yellow and green are available on request. Prices below.
Paypal credit card payments will be charged at $3.50, to cover Paypal charges.
If paying by Paypal funds (Paypal balance) $3 is enough, since I don't have to pay the service fee to transfer funds.
Old Mar 5, 2004 | 04:38 PM
jtc's Avatar
jtc
Begin at the center box (armrest). Unscrew the two screws holding the box down, and pull the whole unit from the back up, releasing it from the two clips at the front.
Old Mar 5, 2004 | 04:40 PM
jtc's Avatar
jtc
Next, unscrew the two screws, and disconnect the cable which powers the cigarette lighter, ashtray, and shifter (if you have auto) bulbs.
Old Mar 5, 2004 | 04:42 PM
jtc's Avatar
jtc
Now to the left lower part, beside the pedals. Using your screwdriver, unscrew the plastic screw holding the panel in, and pry away the panel. It has tabs that attach it to the center console.
Old Mar 5, 2004 | 04:43 PM
jtc's Avatar
jtc
Using the head of your screwdriver, push the center part of this little ingenious device in, and pull out the grommet.
Old Mar 5, 2004 | 04:44 PM
jtc's Avatar
jtc
Now to the right passenger side. This panel is completely smooth, held in with clips. Pry gently outward with constant force, it should pop right out.
Old Mar 5, 2004 | 04:46 PM
jtc's Avatar
jtc
Once again, with the ingenious grommet, push your screwdriver head into the middle, and pop the piece out. You have now completely released the center console, and it should lift right out with the proper angles. If you drive auto, it helps to have your car in neutral at this point to help guide the console out.
Old Mar 5, 2004 | 04:48 PM
jtc's Avatar
jtc
To change the bulb in the ashtray, remove the ashtray and replace with desired bulb colour. This is the bulb that lights the ashtray when the ashtray is open.
Old Mar 5, 2004 | 04:50 PM
jtc's Avatar
jtc
Flip over the center console. You'll see the cigarette lighter assembly, the circled item is the bulb you want to replace.
Old Mar 5, 2004 | 04:51 PM
jtc's Avatar
jtc
Bulb unscrewed, replaced. Now put it back.
Old Mar 5, 2004 | 04:52 PM
jtc's Avatar
jtc
For auto drivers, this is the bulb you want to change out. A simple twist, and it comes right out.
jtc's Avatar
jtc
Once again, bulb replaced, reverse procedure to put it back in.
Old Mar 5, 2004 | 04:53 PM
jtc's Avatar
jtc
Moving on to the gauge cluster and clock mod, first remove the two screws holding in the top of the gauge cluster.
Old Mar 5, 2004 | 04:55 PM
jtc's Avatar
jtc
Next, remove the 3 screws holding the gauge cluster in place.
Old Mar 5, 2004 | 04:56 PM
jtc's Avatar
jtc
With the gauge cluster loose, pull it slightly out of its sitting place. Now on to the climate controls. Twist all knobs all the way to the left, this makes it easier to put them back in later. Simply pull them out.
