View Poll Results: springs
sprint springs 1.8 inch drop
15.00%
dropzone springs 1.7 inch drop
20.00%
h&r`s springs 1.5 front 1.4 rear
50.00%
keep it stock which i wont do because i hate the wheel gap
15.00%
Voters: 20. You may not vote on this poll
need opinions fast plz
Old Jun 28, 2004 | 06:47 AM
illuminati's Avatar
hey guys i need your opinions fast for my 2004 lancer es
here goes i am buying the evo 8 conversion kit i just put on some 17 inch tires with mags and now i want to lower it so far i found 3 options sprint racing springs 1.8 inch drop back and front i believe dropzone springs 1.7 inch drop or h&r`s 1.5 inch front 1.4 rear
which one should i do plz opinions fast if possible dont forget i am putting the body kit and i dont want to scrape it
thanks
stav
Old Jun 28, 2004 | 09:13 AM
4Gaijin63's Avatar
if all you are buying is springs you should consider the Eibacj prokit which can be found at www.roadracemotorsports.com. it is the best spring for your money.
Old Jun 28, 2004 | 11:25 AM
ambystom01's Avatar
I don't think the eibachs fit the es. We're pretty screwed on the springs department in terms of choices.
Old Jun 28, 2004 | 11:29 AM
Danno's Avatar
H&R because of the drop height. 1.5 is ample for the Lancer. I would also be carefull of anything more then a 1" rear drop. not sure about the 1.4 in the rear though. Seems a little too much to me.
Old Jun 28, 2004 | 12:04 PM
illuminati's Avatar
h&r`s not sure if they fit our es
Old Jun 28, 2004 | 09:49 PM
illuminati's Avatar
anyone know anything about the ground effect coilovers i believe there called
Old Jun 29, 2004 | 02:50 AM
ghostrider's Avatar
Ground Control.
I know they fit on the 02-03 ES, not sure if they will also fit the 04 ES. Of all the options, I would highly suggest getting coilovers because of the adjustability. That way you can decide how much drop you want in the front and rear instead of being stuck with a certain amount. Nothing would be worse than dropping your car too much and risking damage to a perfectly good kit!
Another thing to keep in mind also is that the amount of drop listed for the springs might not be the final amount of drop that you end up with 2-4 weeks later once the springs have fully settled. I know plenty of our club members that have both Progress and Tein springs and it drops their car a lot more than the listed amount.
Old Jun 29, 2004 | 06:09 AM
rguija's Avatar
/\ Hey man thanx for the info... I was going to buy some TEIN springs... but I'll wait a little more to buy the coilovers
Old Jun 29, 2004 | 06:39 AM
escodotcarter's Avatar
hey how come ur forgetting about the rrm progress springs
anyway
where can i find H&R springs
Old Jun 29, 2004 | 09:44 AM
StainlessJ's Avatar
How smooth is the ride with ground control's? And what is the range of heights with them?
Old Jun 29, 2004 | 09:18 PM
illuminati's Avatar
i heard with ground control it is pretty bouncy someone just confirm that
h&r;s i am not sure if it will fit out car on there website it doesnt state es when you look for springs make sure it says for the es model because it is different then the other models
Old Sep 17, 2004 | 07:43 AM
cmcd2288's Avatar
i would still go with dropzone cant go wrong with a lifetime warranty and great ride
Old Sep 18, 2004 | 03:01 AM
ghostrider's Avatar
From the website - .5" to 3". Retail is $399 but I just saw a thread with someone selling em for less than half that.
As for ride smoothness it's a little bit stiffer than stock but far from uncomfortable. I've got my car lowered about 2" and the stock struts have held up fine for over a year.
Old Sep 18, 2004 | 03:34 AM
Sentinal's Avatar
I have used H&R springs before from the amount the ones you mentioned lower your car I would guess they were the street springs ( I had race springs about 2.5" drop) they were very stiff but handled great performance in the corners improved greatly and other than camber being messed up ( I should have got an camber adjustment kit) I had no other probs with the springs themselves. For performance they have been the aftermarket springs I have used.
wazzelby
28
Dec 8, 2010 08:19 PM
Corton520
16
Aug 5, 2009 02:21 PM
kromix
Dec 16, 2003 09:05 PM
ChrisS.
Oct 27, 2003 09:42 PM
TooFastOZ
11
Dec 28, 2002 09:33 PM
