Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
suspension question
Old Dec 15, 2002 | 09:56 PM
sonso's Avatar
suspension question
I used Progress springs to lower my car and the car is making all kinds of noises. I mixed up the strut assemblies. Is their a certain way that they have to go in, ex. left and right, facing inward or outward.
Old Dec 15, 2002 | 09:59 PM
SWIFT1's Avatar
first off, are all the springs making noise? . .. secondly, if you are hearing like a rattle sound (or something that sounds loose), most likely the spring is upside down . . .
Old Dec 15, 2002 | 10:04 PM
pjal84's Avatar
Struts are definitely directional in every sense of the word. The spring could be sitting wrong, the shock body itself may be moving and twisting if the fitment is off, brake calipers could be moving since they're mounted to the assembly and then the spring could also be settling in to. Not the best predicament.
Old Dec 15, 2002 | 10:05 PM
ryancb's Avatar
mine make a knocking sound if i launch somewhat fast like not a really slow smooth launch
Old Dec 15, 2002 | 10:15 PM
pjal84's Avatar
Off a hard launch the car is keeling back then moving forward...i guess, does it happen on both the compression and rebound strokes? Front and back? Can't imagine this happening but did you put the rears in front and vice versa? In the end, none of this may be very helpful though and you may just want to take it to a garage. Probably doing quite a number if something isn't facing the way it should.
Old Dec 15, 2002 | 10:17 PM
sonso's Avatar
at first, the left rear was making noise, that was the only one. we switched them around and now both rears are making noise. when you bring the car off the lift do you have to line up everything before putting weight on the springs and struts? they are making a clicking sound under acceleration and deceleration also. ive never seen this before.
Old Dec 15, 2002 | 10:27 PM
hotfire007's Avatar
how can you tell if the springs are upside down or not, i put them in the best way they fit( at least it looked like the best way), i get the clickicking noises as the shock starts to expand.
Old Dec 15, 2002 | 10:34 PM
pjal84's Avatar
Probably best to ask the guys who've actually done a spring install but lining things up is definitely a good thing. Definitely consult the spring installation guide.
Old Dec 15, 2002 | 10:38 PM
hotfire007's Avatar
i used the spring installation guide from RRM and it explained everything perfectly. looking at the spring itself it is hard to tell, the only thing that was diffrent was that on one side of the progress spring it said front. I guess im wondering if that sticker goes on top or bottom. Any ideas?
Old Dec 15, 2002 | 10:45 PM
pjal84's Avatar
Whoooa...top/bottom orientation is wrong? You should have the tight coils on top and the wider ones on bottom. That'll definitely cause a problem.
Old Dec 15, 2002 | 10:48 PM
hotfire007's Avatar
Yea, thats how i got them, now i just have to figure out what is making that noise. thanks for the help, How likely id it that the springs are settling? and how long should i leave it like that before playing around with the setup again?
Old Dec 15, 2002 | 10:53 PM
HobieKopek's Avatar
If this doesn't help you then I don't know what will.
Old Dec 16, 2002 | 03:07 AM
sonso's Avatar
ok well my problem is that i lost track of which one went where. i don't have them upside down. you can tell easily by just looking at it. see the two front ones can go on either on the left or the right. there are two possibilities.
the two rear ones can go either on the left or the right and you can also turn each one to face inward or outward without being able to tell which is correct. thats four possibilites.
Spark Tru
North Texas Evo Club (NTEC)
12
Sep 9, 2013 06:20 AM
evo_il8
166
Jan 21, 2010 03:29 PM
evolucion
14
May 20, 2008 11:46 AM
army685
11
Sep 26, 2005 02:15 PM
Autoxevo
Northwest Region
12
Jul 16, 2005 03:19 PM
