Nitrogen filled tires??
We use this at my shop. It works with temp fluctuations due to the lack, or lesser amount of moisture in the tire. Usually about a 1 psi fluctuation for every 10 degree temp change with regular air, and 1 psi loss for every month you dont check due to the oxygen seeping through the tire. Anyways, it works pretty well but isn't worth 35 bucks. Its a 5 minutes process...35 bucks, hahaha!
