View Poll Results: Do you have noise with your Progress springs?
Yes!
22
61.11%
No!
11
30.56%
Yes! but i fixed it...
8.33%
Voters: 36. You may not vote on this poll
rrm/progress spring noise
I cut the bump stops and still have the problem. It sounds like this isn't specific to the Progress Springs (i have the eibach). It seems like it is common with lowering the lancer. I don't think I have any damage, just noise. Unfortunately, we might have to live with it.
im hoping by letting them settle the noise will go away . . the noise has gotten considerably less since a week ago when i first had them put on . . . hopefully it will get even less after this weekend when i get it aligned and put on my new rims? . . . i think i still might invest in some of that spring insulator stuff to quiet them down even more . . . i cant stand hearing that rattle
i figured out the problem
i am a god lol
on mine aside from not having the rubber things i had to tighten down the screw that bolts everything together, to do this take the schock hold it so it won't turn and then tighten the screw down otherwise it turns and you can't tighten the damn bolt
peace out
thank me later
this explains why it got progressivly worse on some of your cars, the screw just kept getting looser and looser
i am a god lol
peace out
thank me later
i am a god lol
peace out
thank me later
i am a god lol
peace out
thank me later
that's boo. well, i can't find that thread..
i'm gonna see if tightening that bolt help any today.. i hope and pray it does, because i am really getting pissed off by these noises
ok found out that that is only a temp fix i called progress and they are sending me a freeeeee kit that is a "wrap" that goes around the spring supposedly the bottom and tops of the springs bend and hit themselves so this keeps metal from hitting metal call them and get more info if you need it
edit here is the phone number
(714) 575-1193
(714) 575-1193
you can also email Progress bout your problem and give them your address, they will send you the plastic tube also. thats what i did. but i dont think i plan on keeping the spring.
