View Poll Results: Do you have noise with your Progress springs?
Yes!
22
61.11%
No!
11
30.56%
Yes! but i fixed it...
8.33%
Voters: 36. You may not vote on this poll
rrm/progress spring noise
ive read about some people having noise with the progress springs and i wanted an actual count of how many people experienced this. just vote yes or no, maybe give a little side note. thanks a lot!
-Bob
-Bob
Originally posted by cleofis
i've got that noise
..i had someone install it for me, and i actually paid for it too...i wonder if they installed em upside down
i've got that noise
Should have got the eibachs. You need a compressor for them, the progress just sit there, that is what tipped me off. Anyway there is a fix in another thread that involves some of that nylon spiral conduit crap, they just wound that around the coil where they were hitting. Sounds ghetto to me, but that supposedly solves the problem.
i have the noise when i hit bumps, the prob isn't that mine are upside down its that there are rubber bushing that go above the spring that i forgot to put back on, i will put them back on and the noise will be gone, i idn't forget on the rear tires just the front 2
man..my noises have gotten worse!! the clanging in the front isn't so bad, but now my back springs are squeaking!! it sounds like the noise rubbing a balloon would make(if that makes any sense). but it's annoying as hell
should i take them back to the guy who installed them for me and say he put them in upside down?
i just had mine put in today and im hearing some noises from the front . . like something rattling when i hit a bump . . the guy who put them in said he made sure everything was lined up - i even gave him the how to instructions from the forums, so im pretty sure they are installed right, but i have no idea what else the noise could be . . . ?
My eibach springs clatter a bit in the right front, think it's just the spring hitting itself. The rear used to creak horribly, but i got new tires and an alignment the other day, now the creaking is gone. Can't promise anyone that an alignment will fix everyone's car, but it somehow did the trick on mine. Maybe some felt between the spring coils will kill the clatter, or that nylon wrap stuff?!
i have the same problem as my friend wags528, i thought if i dont cut the bump stop, i wont have noise. driving all smooth til i hit a bump then CLINK, CLUNK!! what is the remedy for this problem!? beside i like the drop that progress give. dam those noises
