Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Update: Found the problem, broken stabilizer joint (help)
Old Aug 13, 2005 | 07:42 PM
Offender's Avatar
Alright, the problems I had started having a couple weeks ago was not because of a bad tie rod like the dealership said, the stabilizer joint on the right side is totally broken off. Now, does anyone know if there is a performance replacement for this? The guy at Midas said to check Tien, Energy Suspension, and Eibach. I'll do that a bit later and give an update but does anyone know off hand if there is a preformance alternative for it? It's gonna cost $120 to replace with OEM so I figured I'd try to find performance part first.
Old Aug 14, 2005 | 05:30 AM
gregivq's Avatar
How can you tell if it is broken? Any sounds? Vibration???
Old Aug 14, 2005 | 09:55 AM
Offender's Avatar
There was a squeeking sound whenever I would go over bumbs at low speeds, which I guess is what happens when you have a bad tie rod as well. It is making that sound now because the broken bottom part of the stabilizer link is bumbing into the control arm.
binh
Mar 30, 2014 01:34 PM
EVOlutionary
Mar 9, 2014 10:12 AM
macPSU
Jan 12, 2014 01:34 PM
R/TErnie
13
Mar 24, 2011 11:24 PM
TS8
Jun 1, 2010 05:42 PM
