Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Brake Problem
Old Apr 20, 2006 | 07:47 PM
lanport's Avatar
Brake Problem
I changed my brakes about 2 weeks ago. i recently i started hearing grinding like noises. anyone know why? and another question. how come the passanger side brake pads wear down HELLA fast compared to the driver side?
Old Apr 20, 2006 | 08:12 PM
cableguy5752's Avatar
i changed mine about a week ago and i noticed that the passenger side was more worn than the driver side too. i don't know why though. just thought i'd share that with you. i don't know what the grinding is, mine haven't done that. sorry.
Old Apr 21, 2006 | 08:08 AM
Wallesasuaz's Avatar
Did you guys change your own brakes?
Usually when you change your brakes your rotors need to be grinded down so there won't be any type of ridges that will cause uneven wear on the pads. As for one side wearing out more than the other, could be a bad caliper or something. You can try and bleed your brakes a bit to even out the flow if fluid to each side.
Old Apr 21, 2006 | 08:11 AM
g0damy0uugly's Avatar
yea resurface your rotors before putting on new pads.... the last time i did my brakes i bought cheap *** pads from autozone and then a couple weeks later started eating at my rotors.. don't cheap it out with brakes
Old Apr 21, 2006 | 01:50 PM
lanport's Avatar
Yea theres where i bought them from too. Freakin cheap brakes. Wheres a good place to buy brake pads.??
Old Apr 21, 2006 | 01:57 PM
Shingen's Avatar
RRM
Fox
Old Apr 22, 2006 | 01:34 AM
lanport's Avatar
Originally Posted by Shingen
RRM
Fox
I need to get them now. Any good places in Portland,Or?
Old Apr 22, 2006 | 09:06 AM
SLVROZ_03's Avatar
If I knew any good shops from back home I'd let you know, but it has been a while now... Any slotted rotor (Brembo/Powerslot) and Axxis/Porterfield pad combo will work well together.
Old Apr 22, 2006 | 10:16 AM
N1te's Avatar
RRM
Fox
You can get cheaper rotors elsewhere, as well as the pads. THey are 90 dollars through RRM, you can get Axxis Ultimates for 50 dollars other places.
ugakirk
Feb 9, 2014 07:54 AM
B1147SB
Oct 5, 2012 08:59 PM
sabrinaEvo
Dec 4, 2011 06:53 PM
fimotorsports
MitsubishiParts.net - WA
Sep 25, 2008 07:30 AM
yesevo
Nov 23, 2005 09:50 AM
