Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
performance struts ?????
Old Apr 30, 2006 | 07:33 PM
ILovE WHEELS's Avatar
ok b4 u flame let me explain...ok so ive searched on here and found out that oz struts will fit on a es if u change the top mount.
so my question is since they make an aftermarket strut for the es why cant we (people with oz model) take the es aftermarket strut and put our top mounts on it and make it work? i have some ground controll coilovers that would probably not ride that bad if i had a pair performance struts to put them on.any help would be nice.thanks
Old Apr 30, 2006 | 09:22 PM
blaze_125's Avatar
only aftermarket struts available... as you already know are KYB struts. Even though RRM's website says they're better than stockies(which is most likely true) I probably wouldn't rate them as performance struts.
If you look at the price of ground control coilovers and add the cost of all for corners(KYBs), your total cost will probably be a few bucks shy from a Nexx setup which has been tested and approved by a few members already.
Old Apr 30, 2006 | 11:22 PM
oh i see...the only thing is i already have a set of ground controll coilovers so zero cost there..i was just looking for a sturt that would perform better than the stock ones with the gc coilovers
the other question is any strut avilable from other cars that mount or match the mounting holes at the bottom of the strut
cause if the holes on the bottom fit couldnt we just use our top mounts and use those struts?(does this work or can it)
for example. if ones from like a eclipse fit the bottom holes i can put my top mount on them and buy performance ones
any1 have any idea if this would work
Old May 1, 2006 | 06:08 AM
blaze_125's Avatar
We'll find out in about a week. Once I get my Evo struts.
Old May 1, 2006 | 08:58 AM
but the only thing about that is do they even make performance evo struts?
Old May 1, 2006 | 09:01 AM
blaze_125's Avatar
there are plenty of setups available for the Evo.
Old May 1, 2006 | 09:26 AM
i know there are plenty of coilover set ups but what about adjustable struts?
also i was searching and found out that some one said
Originally Posted by zlancer
well if this helps...my air bag struts are made for a Mirage (MacPearson style) and they bolted right in to my OZ's front suspension.
Originally Posted by StreetLancer
Sky, I was able to confirm that the mirage and ES use the same front parts,
anyone have anyidea which model lancer this is?
so i think ima try and get some mirage front struts and see if they fit,if so i can go out and get the adjustable one
JRR
Jan 10, 2024 01:55 AM
Hayk
Oct 19, 2016 03:17 PM
Hayk
Feb 4, 2016 07:23 AM
Danno
10
Oct 11, 2006 10:43 PM
StreetLancer
26
May 25, 2004 07:06 AM
