Lancer adjustable coilovers
I just bought some coilovers from ebay, and my "friend" is charging me $50 each to install. Total of $200.
Anyways, I wanted to know if they were that hard to install. I have all the tool, but not the knowledge. I could really use mayor help on this guys. Any help will be great. Thanks!
Originally Posted by joberk3
jw but do u have any pictures of the coilovers? ebay tends to have multiple brands for sale.
http://cgi.ebay.com/ebaymotors/02-03...spagenameZWDVW
Originally Posted by silver_lancer
Coilovers are really not that hard to install. Just run a search, im pretty sure theres a How-To on it.
Originally Posted by comatose721
agreed. i've done about 4-5 sets of springs and/or coils....it's really easy. there should be a write up on here.
Originally Posted by david76008
OK you guys, how about if I just follow some How-Tos I found. Can anything go wrong??
Seriously, that's outrageous. A shop would charge less. Hell, a dealership would charge less.
No, you can't do much wrong. Can you take nuts off bolts? Can you put nuts back on bolts? It's very simple to do. Remove old, insert new the same way. It'll probably only fit one way anyhow.
Make sure you get an alignment afterwards, thought.
check this out...This should help you out in some ways...
http://diy.prostreetonline.com/howto...p?articleid=49
Originally Posted by Blacksheepdj
Yeah, you could be a moron and pay $200 for install.
Make sure you get an alignment afterwards, though.
Here is the link to RRM spring install, https://www.evolutionm.net/features/...e/rrmcorner/18 I did my springs and it was a really easy install. I would make sure I had an impact wrench though, makes things alot easier, I bought one form Wal-Mart for 79 bucks then took it back when I was done (they'll take anything back at wal-mart!! LOL)
Originally Posted by lancerman360
you really cant mess anything up unless you lose a nut or bolt, or if you put something on wrong. Its easier than you think.
springs are a cake, but make sure you have the right tools. I installed replacement front struts this weekend and it literally took me 30 minutes from start to finish. Having pneumatic tools helps (need a impact wrench).
edit: I just looked at the ebay link - those are the same sleeve coilovers I bought. )mine were NEX sleeve coilovers). They work okay and are pretty easy to install. If you get stuck installing, lemme know and I can help the confusion - you gotta pop the gold looking ring off the strut and put the rubber spacers on, then slide the metal sleeve over them. Its easy, but if you dont know what to do, its like WTF ..
