Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Broken Wheel Stud
Old Jul 30, 2006 | 05:45 PM
sadude's Avatar
Broken Wheel Stud
Hey guys...in the midst of my recent broken sway bar end links somehow all the excess vibration made my passenger side tire loose which in turn caused me too lose on of my wheel nuts and then jam another one.
In conclusion, I had to break off the stud in order to remove the wheel nut, how do I remove the broken wheel stud? I already bought new studs from the dealership.
thanks guys
Old Jul 30, 2006 | 07:26 PM
BigP436's Avatar
hit it w/ a hammer till it pops out.. what you put the new one in MAKE SURE you use a steel wheel to tighten it on. the force it takes to pull the new stud threw can hurt an alloy wheel very easily. then once its on, for for a short ride, and tighted it again.
Old Jul 30, 2006 | 07:34 PM
sadude's Avatar
do you need to take off the rotor also or will just the wheel off being enough?
can't i just tighten it down with just the rotor on?
thanks for the reply man
Old Jul 30, 2006 | 07:40 PM
twardnw's Avatar
I wouldn't do it directly against the rotor, being a cast part it could break easily, since steelies are pressed, they will resist that type of force much better (use your spare)
Old Jul 30, 2006 | 07:42 PM
zlancer's Avatar
take the rotor off, hammer out the old stud, slide in the new stud, take like 5 washers and put in on the new stud than a lug nut, blast it on with an impact gun until it is fully seated.
Old Jul 30, 2006 | 07:43 PM
BigP436's Avatar
he got to it first
Old Jul 30, 2006 | 07:45 PM
sadude's Avatar
cool...so it'll be a small project...i'll try to take care of it after work tomorrow
I don't have a impact wrench...I am thinking of buying one, how many gallon compressor should i get?
are those new electric impact wrenches any good?
thanks guys for all the help
Old Jul 30, 2006 | 08:00 PM
nothere's Avatar
even a battery impact will do it, but an electric one is less expensive and mo power. unless you need air, electric is easy.
Old Jul 30, 2006 | 08:01 PM
sadude's Avatar
oh I didn't no electric was more power...why would you need air?
Old Jul 30, 2006 | 08:08 PM
nothere's Avatar
110 volt is more power than battery impact. it takes a pretty good sized compressor to run an impact wrench.
If you don't need air for something else, like tires, inflate air mats... electric is the way to go.
Old Jul 30, 2006 | 08:14 PM
sadude's Avatar
Cool...yah I already have those mini air compressor for the tires and stuff...so I'll look into a nice electric one.
balleronabudget
Aug 30, 2015 08:35 AM
06redrocket
10
Mar 8, 2011 06:45 PM
blackonblackevo
22
Aug 13, 2007 04:55 AM
evoXIII
Jun 3, 2007 06:56 AM
lanport
Jun 7, 2006 05:34 AM
