Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Alignment needed?
Old Oct 16, 2003 | 02:20 PM
dodgerslover's Avatar
Question Alignment needed?
I just got new tires and new brakes. My car seemed to be pulling a bit towards the right before I got new tires & brakes, now when I let go of wheel it obviously goes to the right. I figured I need to get my wheels aligned, so I called the local gas station and I was told that this should be covered by the warranty and give the dealer a call. Is this true?
Old Oct 16, 2003 | 02:27 PM
Neal@tirerack's Avatar
You might want to go the free route and check your tire pressure first. Misbalanced tire pressures can cause a car to pull. They might have inflated them wrong when the new tires were installed. Just a thought...
Old Oct 16, 2003 | 02:31 PM
Like the sound of the "free route". I'll check after work.
Thanks
Old Oct 16, 2003 | 06:29 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
did you get grippier tires, wider tires, larger rim diameter, lower profile tires, or a combinationg of the above? In that case, you are probably experiencing the same "torque steer" you felt before, but more prominent with your improved traction. Lancers (and most FWD cars) are known to pull to the right for this reason. I learned to drive accordingly, and then my alignment guy put 1/4 more camber on the left side to counteract it, but I don't notice any difference.
Old Oct 18, 2003 | 07:17 AM
Blacksheepdj's Avatar
If your dealership is anything like mine, they won't give you a free alignment. The only reason I got one was because I had the car two weeks and they decided I couldn't have possibly screwed up the alignment as bad as it was. Normally, they assume you hit a pothole and that's your fault, so you pay. But I could be wrong.
joonvang
Feb 24, 2017 08:08 PM
TxFAkuma
Apr 15, 2016 04:12 PM
AhmadHasib
Nov 29, 2007 07:07 PM
initialDRacer
21
Jun 3, 2005 10:30 AM
