Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
brake fluid
Old Dec 14, 2003 | 08:28 PM
bobaab's Avatar
brake fluid
I was watching some japanese tuning videos and a basic upgrade seems to be upgrading the brake fluid. Now i didnt do a search cause im lazy, and i havent heard too much talk about brake fluids.
My question is, how would changing brake fluids change performance of the brakes and what kinds of brake fluids there are. Thx in advance!
Old Dec 14, 2003 | 08:36 PM
kuniboy's Avatar
the brake fluid in the car right now is Dot 4 rated. That's pretty good for street use. Changing the brake fluid will not make you barke better. The difference in brake fluid simply consist of the boiling point of the fluid. DOT 1-4 the higher the # the higher the boiling point. If you are racing on the track, then upgrade the fluid.
Old Dec 14, 2003 | 08:43 PM
colateralgees's Avatar
From: West Texas, where the roads are straight and long, and the law is few and far between
I use ATE Super Blue in my cars. Aside from having a super-high dry boiling point of over 500-degrees F, it absorbs moisture from the atmosphere much more slowly than "normal" brake fluids.
Therefore, you have less corrosion (long-term) in your brake system, and you can go longer before changing it out (if desired). Also, you won't be as likely to boil it and lose your braking feel....
Old Dec 14, 2003 | 08:50 PM
4Gaijin63's Avatar
there is DOT-5 also.
Old Dec 14, 2003 | 08:56 PM
yep!....
but aren't most of those (DOT-5 brake fluids) silicone based?...and some systems are not equipped to handle the silicone fluids without damage, if I'm correct.....but maybe that's not the case with the newer cars, I don't know for sure...
Old Dec 14, 2003 | 09:13 PM
bobaab's Avatar
thx for the replies guys, i just read up on some things about brake fluids and got the basics of it. im gonna check what type of fluid the usdm lancers use..if it's dot 3 i will be upgrading to dot 4 by the time i start to autox next season.
zeero260
May 20, 2025 05:50 AM
mitlan
May 15, 2015 08:09 AM
yenny
Aug 23, 2012 08:03 PM
dprez25
Aug 14, 2012 05:53 AM
lutionDog
Aug 10, 2010 03:45 AM
