Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Will I rub?
Old May 3, 2011 | 09:39 PM
Torntech's Avatar
Question Will I rub?
So I'm probably going to lower my car on Tein S-Tech this weekend. Drop is about 2" front and 1.2" rear.
My tires are 225/40/18 and my rims are 18x7.5 offset +38.
Do you guys think I'll rub?
Old May 4, 2011 | 06:33 AM
Torntech's Avatar
bump for a reply
Old May 4, 2011 | 07:51 AM
scottgts's Avatar
you will be fine
Old Jun 8, 2011 | 01:25 PM
fordp's Avatar
There should be plenty of clearance left (though I am not sure about fullll turn)
Old Jun 8, 2011 | 07:16 PM
Lancer XI1's Avatar
You ll maybe have rub if theres lots of passengers in your car too.
Old Jun 18, 2011 | 12:08 AM
quickflips's Avatar
with passengers def will rub but otherwise, maybe only on turns. as stated above
Old Jul 26, 2011 | 04:42 PM
Jeff9455's Avatar
Hello, need to know if my Lancer GTS 2011 will be okay if I install 235/40/18 - 9" wide rims. I have friend running 235/35/19- 8.5 wide, he has no complains. If these will not work what is the biggest wheels I coud put on it without rubbing?
Jeff
Old Sep 2, 2011 | 10:01 AM
bpassey's Avatar
I was running 19x9 up front and 19x10 in the rear. Front had clearence all day everyday. The rears rubbed on the smallest of bumps or if you had someone in the back. I rolled and pulled the rear a good 3/4" and was fine except for massive dips and then they only hit the little tab that connects the rear bumper to the panel. I have the Tein S-Techs.
Old Sep 2, 2011 | 10:45 AM
lancer0220's Avatar
need to know offset to tell if it will rub
sullysnet
18
Jul 31, 2019 10:39 AM
McRooster
Apr 21, 2017 07:12 AM
oftheheavens
10
Jul 6, 2010 11:56 AM
Sufu
27
May 19, 2010 08:56 AM
EndlessRed
30
Nov 8, 2009 12:43 PM
