Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Suspension question
Old Sep 24, 2002 | 07:53 AM
Joseanevo's Avatar
Try coil overs if not then try progress springs but i will go with the Coil Over Set Up
Old Sep 24, 2002 | 09:30 AM
zeroIIracing's Avatar
go ghetto cut a coil...its cheap and will get ya low...ride may suck a little though...i may cut a coil to see how far it sits until i get my coilovers...hope the struts can hold up for a couple of months...
Old Sep 30, 2002 | 12:15 PM
Sonantoni's Avatar
As in terms of the Tein coilovers, they are a kit consisting of the spring w/adjustable sleeve and 16 level adjustable dampers, which runs you about $1250. Now the ground control is the spring and sleeve set, which you will have to use stock or ralliart struts, runs you about $350. You will get a better ride from the Tein setup. I have heard it many times, you get what you pay for
Old Sep 30, 2002 | 08:25 PM
ROCK's Avatar
Tein is good. But when people say coilovers make sure they mean shock and spring set togther. Cheap coilover spring sets alone lower the car too much and then blow up stock shocks or ralliart stuff. Even turned up to the highest settings car is still more than 2 inches lower. That is too much! Otherwise be safe with Eiabach or Progress springs
ROAD/RACE
http://www.roadracemotorsports.com/
Old Oct 2, 2002 | 12:31 PM
Sonantoni's Avatar
Talking
Thanks Rock I meant to say that in there somewhere. Just put in my Eibachs on, feel great. A bit on the bouncy side so I know that a much lower drop would really screw up the stock struts. Road///Race Rocks
Old Oct 2, 2002 | 06:45 PM
Pimpson's Avatar
I would rather not thank you.
This trick is just one of the things that we lament about when talking about Rice. If you do this may as well hollow out the pre-cat and get the speed stickers done too.
garithp
29
Jul 25, 2010 04:33 PM
Hrdcoreathlete
11
May 1, 2009 08:37 PM
LVLANCER
Apr 8, 2009 05:28 PM
SpeedI2acerX
Sep 26, 2008 12:25 PM
aerialcombat
Sep 20, 2002 07:19 AM
