Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
quick question on offset
Old Jul 22, 2004 | 05:13 PM
Drive02Lancer's Avatar
http://www.motegiracing.com/wheels/d...yle=2131&desc=
those are the wheels im getting, Motegi MR3's in Gunmetal.
they are on my friends cougar right now(he has 4x108 and i have 4x100)
according to Motegis site, the wheel itself is 24lbs and the offset is +40.
so the wheel is 17x7 and has a +40 offset.
is that safe to run if i also get Progress Lowering springs that lower the car 1.8"
i looked in the info that they have in the sticky but it doenst list 'safe' offsets.
THANKS!
rich!
Old Jul 22, 2004 | 05:25 PM
TURBOit's Avatar
are you in an oz? for an OZ the offset would be off
but for the es/ls i forget the models, it should be straight
cheers
p.s. i run 17x7.5" rims on my Acua CL and the offset is liek waaay off from what it should be but drives fine and dany
Old Jul 22, 2004 | 05:37 PM
its an ES.
thanks for the reply bro
sucks that the wheels weigh so much though haha
Old Jul 22, 2004 | 11:29 PM
TURBOit's Avatar
yup, the wheels on the acura weigh 25.5lb + a 235/45/17 tire, talk about weight
Old Jul 29, 2004 | 12:15 AM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Those wheels will fit fine. And it doesn't matter if it is going on an ES or an OZ/LS. The stock offsets are off becaus the stock rims are different widths.
The concern is when you said he has 4x108 if you plan on buying his rims that won't fit your 4x100 pattern. Other than the bolt pattern, the rim would fit fine. They are porky wheels at 24 lb though. For reference, the stock OZ rims are 15 lb.
hearnoevo
For Sale - Wheels / Tires / Suspension / Brakes
Mar 22, 2017 07:10 AM
bakuro117
19
Feb 7, 2013 07:14 AM
Evocore
Dec 20, 2012 08:19 PM
chucksss
Sep 4, 2012 11:47 AM
hlm
Jun 2, 2009 08:16 PM
